Question about Oregon Scientific Measuring Tools & Sensors
On BAR 182Hg How do I get the Main Unit to take readings at a remote sensor's location.It only shows old location readings.
Posted by John Phillips on
1 Related Answer
Anonymous
SOURCE: remotes don't work
on the battery pack of the remote there is a red button that says sync and there is a red button on the console by the sd card port press both of the buttons at the same time and it will work.
Posted on Mar 07, 2009
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
Changed batteries and the outside temperature still does not show
Bring the outside sensor inside. Take the batteries out of the sensor and out of the main unit. Wait 10 minutes. Put the batteries back in the remote sensor. Put the batteries back in the main unit. Do not touch any of the buttons. Wait 10 minutes. If the remote temperature is not showing within 10 minutes, try again. Once the remote temperature is showing, you can set the clock.
Jan 08, 2011 | La Crosse Measuring Tools & Sensors
The weather Forecast Icons don't change on my honeywell weather station model # TE852W
This problem could arise due to various reasons
1)Replace the batteries in remote sensors
When the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and hold
DOWN on the main unit.
2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.
3)Reset the unit and check
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 11, 2010 | Honeywell TE852W Weather Forecaster With...
Both remotes for my Wii suddenly stopped working. I think it's the ir sensor, but how can I be sure? Both remotes have fresh batteries and were working  fine yesterday. Now the wii does not register...
make sure the sensor bar is plugged in and oriented properly. If thats all ok I would be inclined to believe its the sensor bar, but you might try nintendo customer support before you go out and buy one.
Mar 04, 2010 | Nintendo Wii Console
Wii remote keeps losing communication with the main unit
It sounds like your sensor bar is going out. I have heard from numerous people that they go bad and start acting very sporadic( somedays they work and somedays they don't) Also check to make sure your bar is sitting level on your T.V. and not pointing up or down. If it is the slightest bit off then the bar can't "see" the remotes all the time.
Aug 10, 2009 | Nintendo Wii Console
Remotes don't work
Mar 07, 2009 | Nintendo Wii Console
The pointer hand is not showing on the tv screen
it is probally your sensor bar try moving that or go to sensor bar settings and change settings there
Jan 24, 2009 | Nintendo Wii Console
Broken wii remote
Try windex on the sensor bar on top of your TV. Also check that the sensor bar is properly connected, it's not reading that particular remote.
Nov 28, 2008 | Nintendo Wii Console
Wii
(1)
Verify that the cable bar sensor is plugged into the back of the Wii console and that the sensor bar is properly aligned with the centre of your TV screen.
(2)
Check that the Wii remote is synchronized with the console using the POWER button on the remote control to turn on the Wii console. (The POWER button is the white button with the red symbol which is located in the upper left corner on the Wii remote.) If it does not work, try to synchronize the remote control, then turn the console and controls that respond correctly to commands.
(3)
Verify that the distance between the Wii remote and the TV display to be between 1 and 3 meters, that there are sources of intense light that can interfere with the proper functioning of the remote (read Guidelines game for Wii for more information ) And that the sensor bar is placed correctly (see Setting up the sensor bar). Avoid the presence of sources of infrared light as electric stoves, gas propane or kerosene, candles, fireplaces, stoves or other heat sources close to the console.
If the steps described above do not solve the problem, the sensor bar could have a problem. Read the following instructions:
On each side of the sensor bar are five infrared lights that located the position of the Wii remote. If these lights do not work, the cursor on the remote will not appear on the screen and you can not step through screens of settings. To see these lights, you must look on the LCD screen of a digital camera or a mobile phone. Verify that the sensor bar is connected and that the Wii console is turned on, and then framing the bar sensor so that it appears on LCD camera or cellphone. If you see five infrared lights on each side, the sensor bar works. Maybe you'll need to slightly adjust the position / tilt the camera or the telephone, but is rather easy to see these lights on the LCD screen
Jun 22, 2008 | Nintendo Wii Console
Measuring Tools & Sensors Logo
190 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
