Question about Intermatic Hardware & Accessories
There is nothing in the display of my Intermatic Model ST01, even though I substituted a new battery. What could be wrong? Tom
The Intermatic Model ST01 controls the soffit lights on my house. The display was flashing "Battery". I did not have a lithium CR2 battery replacement until today. When I replaced the battery, nothing shows on the display screen. I tried two different new batteries and checked the breaker for that circuit. What is wrong?
Posted by Tom Archer on
1 Related Answer
Anonymous
SOURCE: I want to replace the
The battery compartment is located behind the pull-down door
Pry open the door with small screwdriver of fingernail file
http://waterheatertimer.org/ST01C-program.html#battery
If the battery goes dead on the Intermatic ST01C or EJ500, the screen will not display.
When replacing battery, wipe clean all the terminal points for battery and battery carriage
If the new battery does not restore the screen, then the timers needs replacement.
http://www.aplussupply.com/intermatic/timer.htm
Posted on Nov 03, 2010
The timer display is blank even after plugging in to charge it. Also pressed reset and that did nothing
Change battery? Applies to Ei600, ST01, EJ500
http://waterheatertimer.org/Programmable.html#st01
Timer has gone bad, timer not rated for freezing temperatures, timer and load do not match
Troubleshoot timers:
http://waterheatertimer.org/How-to-troubleshoot-timers.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 10, 2015 | Hardware & Accessories
Intel self adjusting in-wall timer
Reset timer by holding down on-off button then press and release small round reset button. Then release on-off button. Display should flash 12:00
This timer uses CR2 battery.
If functionality is not restored after new battery and reset, then timer has probably gone bad?
ST01 timer has 1 year warranty from intermatic.com
gene
h
Jul 03, 2014 | Intermatic Inc. ST01C Digital In-Wall...
Intermatic ej500
Florescent bulbs are not discontinued.
Incandescent bulbs are being phased out so you can save electricity to run your great-big 600 watt TV....
http://waterheatertimer.org/What-is-3-phase-electric.html
Or, in a few years from now, you can support the economy and buy another timer:
Buy new EJ600... same keypad as EJ500, except different wiring since neutral wire required
or
Buy ST01 or Ei600 timer: identical wiring to EJ500, same dawn-dusk or programmable options, higher load rating, works with any voltage, CFL, LED etc, different programming steps, different battery.
Ej500 has 1 year wareanty
ST01 has 1 year warranty
Ei600 has 5 year warranty
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ej600
Gene h
Jan 20, 2014 | Hardware & Accessories
I am unable to set the auto on and off
If reset does not restore functionality, then timer is bad, or in case of ST01 timer, the CR2 battery may need to be replaced.
1) Timer model and brand are unknown.
Copy following link for ST01 timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
2) Add a comment and describe timer in detail, and add if this is new installation or older timer that stopped working.
Dec 26, 2012 | Hardware & Accessories
I want to replace the cr2 battery.Where is the battery compartment for the Intermatic model ST01 self adjusting wall switch timer?
Nov 03, 2010 | Electrical Supplies
How do I replace batteries in the ST01 series timer
The Intermatic ST01 uses a CR2 3 Volt-DC battery to operate the "click-clack" ON - OFF function of the timer.
In order to change the battery, simply pull down the flap just below small display screen. This is the manual switch that you can push to turn the timer on and off.
Just use your fingernail at the top of the door flap and pull down, it will open up and reveal another small tab. This is the battery holder/tray.
To open this, either use your fingernail or a small flat bladed screwdriver at the top to slide out the battery holder tray.
If you remjove and replace the battery within 30 seconds or less, you won't have to reprogram the time/day/date/year. Otherwise taking longer you'll have to reset the time and date feature of the timer.
Don't worry, the timer remembers your program ON - OFF cycles regardless of whether the battery is in the timer or not.
Hope you find this Very Helpful and best regards!
Aug 24, 2009 | Intermatic Hardware & Accessories
Hardware & Accessories Logo
222 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Mike
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
