Question about Samsung SL310W Digital Camera
When powered on the lense comes out beeps twice then powers down.
I power it on the lense comes out it beeps twice then powers down. I am able to look at my pictures but not take new ones.
Posted by mocha_cita on
Steve Mason
    Sergeant:
  • 311 Answers
Low battery power, replace batteries
Posted on Aug 05, 2009
I'll push the power button and the little green light flashes it beeps and the lense comes out just a tiny bit but then in stops goes back in and beeps twice and it's still off. Is there and...
First check the battery. Charge the battery to full condition or change with new battery and try to turn on your camera.
Or you can put off all batteries and memory card, wait for a moment, then put in again and turn on your camera.
Hope this help
Feb 09, 2011 | Casio EXILIM 10.1-Megapixel Digital Camera...
Turn the consul on and it says a serious error has occured contact technical support
Try holding power button down until it turns on and shuts off then hold power button down until it beeps twice release power button a menu should come up. You need a memory stick also go get the latested update from playstation network and install it on memory stick then plug it in to your ps3 and on that menu there should be a option for updateing.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
My camera light comes on when i press the on/off button and the lense comes out all the way but then goes in abit, and beeps twice, i then click the power button again and the lense goes in, beeps again...
The problem you describe is power related, and is usually caused by one or both of the following:
1. Your batteries may need to be replaced. Batteries get old and lose their ability to accept and hold a charge, so they may be very low even with an overnight charge. Check the battery power with a voltmeter if possible, but batteries often need replacing if they are a year or more old.
2. Corrosion buildup on battery and camera contacts is a common problem, especially if a camera is idle for long periods. Remove the batteries and check all contacts for a white, green or blue buildup. Even if you don't see anything, wipe the battery contacts and the camera contacts firmly with a clean dry cloth. Heavy buildups, if present, may require cleaning with a fine wire brush, steel wool, or sandpaper. After cleaning make sure that there is no buildup residue in the camera's battery compartment. Then install and charge the batteries.
Other possibilities, although rare, are problems with the charger or the camera's power circuitry. You can check the charger output with a voltmeter, but troubleshooting the camera's circuitry requires a professional camera shop.
Bill B.
Nov 01, 2010 | Samsung HZ10W / WB500 Digital Camera
Console wont come on red light goes green then yellow flashes then flashes red
its an error. hold down the power button till it beeps once. the hold it again till it beeps twice. The moment it beeps twice take your finger off and instantly hold it down again. your ps3 with give you 5 onscreen options, hit #3 and only number 3. that should fix the problem. You can also youtube "how to fix disk error on ps3" and people will should you how to do these stated steps.
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
Code (Vclr) on screen and one beep then two beeps twice.
Your memory modules are faulty (or dirty). Try them one by one and clean the both the modules and slots with alcohol (or Contact Cleaner).
May 17, 2009 | Dell OptiPlex GX240 PC Desktop
Turns on four beeps and it shuts down
I was all over this site and the only solution was to send it into repair for the "4 beeps and shut off" problem. I found another site that talked about lense errors, and one of their suggestions was to take the camera, lense up, smack it into your other hand (not too hard) (screen down toward your receiving hand) while the lense was out. You have to be fast, because when you power on, the lense comes out, and you have about 2 seconds to do it. My first light smack, and the camera came alive again! They also talked about lightly tweaking the lense while it was out in case it fell off track or skipped a tooth, but that wasn't my problem apparently!
Aug 08, 2008 | Casio Exilim EX-S600 Digital Camera
WONT WORK
hold down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system1.gif on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Samsung SL310W Digital Camera Logo
321 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
