Question about Bunn Coffee Makers & Espresso Machines
Bunn coffeemaker leaks cold water from bottom?
Posted by Roxane zemcik on
5 Related Answers
Gord Thurston
  • 131 Answers
SOURCE: empty bunn coffeemaker
The easiest way to empty these brewers is to turn them upside down over the sink. Turn it on it's side, always keeping the fill hole down toward the sink, and keep on going until you have the unit completely upside down. If there is a push switch under the lid to stop water from going into the pot until the lid is closed, you will have to keep this pushed in until the unit is empty
Posted on Feb 11, 2009
Gord Thurston
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
atbsmmom
  • 189 Answers
SOURCE: My Bunn coffeemaker NHB is leaking from the bottom
If you will call Customer Service with your Model and Date Code located on the bottom of the brewer, we can assist you with this problem.
Posted on May 19, 2010
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
atbsmmom
  • 189 Answers
SOURCE: bunn coffeemaker leaking
Is this a Bunn or a Krups-you have both listed.
Posted on Jul 01, 2010
My bunn coffeemaker NHS-B trip the GFI. Where do I find the code date on my brewer?
The NHS-B has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the thank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
P.S. If you did splash too much water then wipe up as much as you can. Leave it out on a towel or paper towels to allow the excess moisture to evaporate. If you dump all the water out of the brewer (and tank) then you will need to pre-fill it with a pot of water PRIOR to plugging in the brewer. Follow the set up instructions in the manual. Let it heat up and try again. If it's still leaking then there is a hole in the tank. Call for service.
Dec 29, 2017 | Bunn Coffee Makers & Espresso Machines
Bunn coffepot will not heat or turn on.
after nearly 8 years of service a water leak shorted the heating element and the short caused a small metal thermal fuse to open
Sep 20, 2017 | Coffee Makers & Espresso Machines
Bunn automatic coffeemaker leaks water after making a pot
Tank and tank components should be delimed regularly
depending on local water conditions. Excessive mineral build-up
on stainless steel surfaces can initiate corrosive reactions resulting in serious leaks.
Feb 02, 2013 | Bunnomatic Corp. 10c Professional Brewer...
Hot water leaks out the bottom when filling resevior with water of my Bunn coffeemaker GR10-B
If you will call 800-352-2866 with the model and date code and we will be able to help you resolve your issue.
Jul 01, 2010 | Bunn GR10 Coffee Maker
I have a Bunn coffeemaker and it is not that old. It leaks from the bottom when you fill it with fresh water for a new pot of coffee. The number is NHB code date is 204305. Do you have any ideas?
The brewer probably has a bad seal or gasket. By the date code, your machine is 5 years old. If you call Bunn Customer Service they will be able to offer you an exchange of your old brewer for a new one at a reduced price.
May 29, 2010 | Bunn NHB Coffee Maker
My Bunn coffeemaker NHB is leaking from the bottom onto my counter. Can this be fixed?
Apr 28, 2010 | Bunn NHB Coffee Maker
Water seeps from under the bunn coffeemaker about 1 cup of water has to be dried off countertop, can this be repaired?
If you can provide the date code located on the bottom of the brewer, I will be happy to offer a solution to your leaking problem.
Jan 09, 2010 | Bunn NHB Coffee Maker
We find water under the coffeemaker in the morning.
Sounds like a leaking water pipe from the water source, unless you have a over temp heater and this results in steam and dripping.
Mar 30, 2009 | Bunn VPR Coffee Maker
Bad tasting coffee
you can always clean a coffeemaker with vinegar, but always pour in cold, so you can do it twice or more, but dont re-use the stuff you just used, wait till it's cold or just use some other.after use clean by let water through 2 or 3 times, (also only cold water)
Jan 28, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bunn Coffeemaker CWTF35-4
Hook it up to cold water. It has a heating element in the tank that heats the water.
Oct 24, 2007 | Bunn RL Coffee Maker
Coffee Makers & Espresso Machines Logo
74 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
Marvin
Marvin
Myrddin R Emrys
Myrddin R Emrys
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
