Question about Smith Corona Office Equipment & Supplies
Lock key light keeps blinking. can not unlock keys on smith corona SL460
Posted by John Milligan on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Smith Corona Typewriter SL460:
The Lock button might be stuck. If someone was typing too fast, I believe it can "Overload". You may have to dis-assemble to see if button is stuck. I worked on one of these a while back.
Posted on Oct 16, 2008
Anonymous
  • 183 Answers
SOURCE: Smith Corona SL 460
Could be the printhead is at the right margin. But, if you hit the return key and nothing happins, it could be a bad board, power supply or transport motor. When you turn the machine on, does the printhead move all the way to the left, spin the printwheel and move to a set position?
Posted on Oct 24, 2008
Anonymous
  • 183 Answers
SOURCE: smith corona xe6100 keys locked
there is a KB ON/KB OFF switch on the right side of the keyboard, it should be in the ON position
also on the left side the switch should be in the TYPE position
if that doesn't make it work, there is a problem with the main board or power supply that will need a visit to a repair shop
Posted on Nov 29, 2008
Eric Sandbo
  • 159 Answers
SOURCE: how do i reset the wheel on a smith corona sl460
The typewriter has a spring at one spool to keep the correction ribbon taut. If that spring is broken or out of place, the ribbon will always get in the way of the wheel.
If both ribbons are correctly set tight between the wheel and the paper, the typewriter will reset the wheel at power-on.
Some models reset the wheel every time you close the cover. You can see and hear it if it does.
Posted on Feb 18, 2010
tomatojim
SOURCE: can't unlock typewriter keys. Smith corona Model
got a free xl 1000 typewriter but the keys are locked and no code to unlock it... help?
Posted on Jan 21, 2011
I found a 1964 smith corona manual typewriter but the keys are stuck like in a lock position. Where is the release?
You could try the shift keys. On mine, I have two blank white keys at the bottom left. When I had a similar problem this helped. You also may have to check for rust, dirt, etc, which can cause keys to lock. It may just need a good cleaning and light greasing of key mechanisms. There are many great websites that show step by step instructions on cleaning and maintenance. Hope this helps.
Jun 26, 2017 | Smith Corona Office Equipment & Supplies
Can't unlock typewriter keys. Smith corona Model 5A series SL 470
Jul 22, 2010 | Smith Corona Wordsmith 100 Typewriter
How do i reset the wheel on a smith corona sl460 electronic typewriter? the correction ribbon keeps coming out of place
Feb 16, 2010 | Smith Corona Office Equipment & Supplies
My Smith Corona XE1950 is in the lock mode. how do you unlock it
my smith corona xe 1950 is in the lock mode. how do you unlock it?
Dec 08, 2009 | Smith Corona Wordsmith 100 Typewriter
Caps lock
There isn't a "code" key, you just press the Shift key.  Unless you have a faulty machine, this is what removes the Caps Lock.
Apr 10, 2009 | Smith Corona Wordsmith 200 Typewriter
Smith Corona Typewriter SL460: The Lock button is flashing and nothing works.
Oct 16, 2008 | Office Equipment & Supplies
Unlocking a typewriter.
I'm a bit confused on this one. I have a XL 1000 and it has no display. How can it "say" it's locked? Some of the Smith Coronas have a printhead lock to keep it from being damaged in transport, but not this model. Need more info.
Oct 03, 2008 | Olympia Office Equipment & Supplies
Smith Corona SL 460
Aug 21, 2008 | Smith Corona Wordsmith 100 Typewriter
Corona smith premiere 100 typed writer
El problema de tu Maquina es que tiene un Censor de Cubierta Abierta en la esquina de carro impresor lado izquierdo y esto no esta conectado o no lo esta oprimiendo la cubierta cunado la cierras , revisa esa area
Apr 22, 2008 | Smith Corona Wordsmith 200 Typewriter
233 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Ekse
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
