SOURCE: My third brake light is out and needs replacing
If I remember correctly, you need to pop off the plastic trim panel on the inside of the trunk to access the wiring. Just unplug it after removing all the screws and it should come out.
Posted on Aug 05, 2009
SOURCE: no brake lights 2008 hyundia accent
check brake fuse. if its good then you need a new brake light switch, its located on the stering coulom above the brake peddle
Posted on Mar 17, 2013
SOURCE: 2009 mini cooper clubman
It means that your vehicles computer has detedcted an issue.
Go to a part store and get them to run their diagnostic computer on your vehicle to see what fault code (s) show up, they will also tell you what the code means and how to fix the problem.
Hope this helps.
Posted on May 17, 2013
SOURCE: Mini Cooper Clubman S engine light
Could be the computer did not like the change in ratio if the size of the tires are different. You would need to get the trouble codes checked to proceed.
Posted on Jul 12, 2014
Aug 15, 2016 | 2009 Mini Cooper Clubman
Oct 20, 2014 | 2008 Mini Cooper Clubman
Jul 12, 2014 | Mini Cooper Cars & Trucks
Apr 19, 2013 | 2008 Mini Cooper Clubman
Sep 24, 2012 | 2008 Mini Cooper Clubman
Apr 13, 2012 | 2008 Mini Cooper Clubman
Jul 07, 2017 | 2008 Mini Cooper Clubman
Oct 28, 2009 | 2008 Mini Cooper Clubman
Oct 10, 2009 | 2008 Mini Cooper Clubman
Jan 19, 2020 | Golf
Oct 16, 2019 | Golf
Oct 11, 2019 | Golf
250 people viewed this question
