Question about Nortel Lands Phones
Have Nortel system. When call comes into line three, it won't recognize any buttons pushed to go to extension. All other lines work fine
Posted by dave on
Cabanaboyz
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 122 Answers
Do an inquiry to find out what is on the button 1st.
On hook
[FEAT] *0 and the button should show what it IS not what it should have been
Posted on Jan 23, 2019
5 Related Answers
Anonymous
  • 201 Answers
SOURCE: dedicated fax line on system phone
If you have a dedicated fax line, the fax should be connected directly to the phone line. If you have the fax line connected to one of your station ports, you may be able to see which LED lights up on your phone when the fax goes off hook. Or you can just try intercomming all extensions in order until the fax rings.
Posted on Oct 05, 2007
Anonymous
SOURCE: Nortel 1140E IP Phone, Expansion Module 1100 series not working
If you're running on a hosted PBX, the expansion module will not work. It only works on premis based systems.
Posted on Mar 24, 2009
Anonymous
  • 18 Answers
SOURCE: Nortel M7310 Phone moved to another jack, now no incoming calls
The reason your phones config is not the same as before is because configuration goes by what extension it is. So if you plug your phone in somewhere else, unless you have DN's configured, your extension changes, so say it was extension 21, but now that you moved it, its now 23, those settings remain on extention 21, so if you bought another phone and plugged it into were extention 21 is, it would have the settings that your old phone had before
To access the intercom by just picking up the handset, Press Feature **CONFIG (266344), Select <A. Configuration>, then go to <2. Line Access>, Select that and enter the extension of the phone you want to have access intercom by just picking up the handset. Scroll until you see <Intercom Keys: #,> make sure you have at least one intercom key. Then scroll until you see <Prime Line: #>, Press change until the display reads <Prime Line:I/C>  And there you go. Hope i didn't confuse you
Posted on Oct 02, 2009
greg411
Greg Standerfer
  • 45 Answers
SOURCE: how do I program the line redirection feature
If you switched phone companies and the feature stopped working you probably had Call Forward Busy/No Answer from AT&T. If you use the call forwarding in the phone it will use two phone lines for the entire length of the call. Call Comcast and have them add Call Forward Busy/No Answer and tell them the number you would like your calls forwarded to and the ring cycle (the number of rings on no answer).
Posted on Apr 19, 2010
Anonymous
SOURCE: RCA 25414 message light... doesn't
Fix for message light blinking on ECA 25414. Many folks have changed phones or bought used phones to find the message light blinking on the phone especially on lines they don't have. That is what I found on used phones. Leave yourself a message on any phone. Now plug that line into the correct jack in the back for the line that is blinking in other words line 1 or 2 or 3 or 4.. Call the number from the line you plugged in and retieve and delete that message. Hang up and shortly the message light on the phone should go out.
Posted on May 18, 2010
Messaging is inactive on all lines after push functions button and enter 981
Hi. Inactive feature often means that there's a problem with your connection to the call pilot. Do you have lights on your call pilot? Did you assign a mailbox to the extension you're working on? Did you remember to connect the call pilot to a station port?
Jun 11, 2015 | Nortel T7316E 2-Line Corded Phone
Access call pilot manager
Hi Kathryn,
I'm assuming that you mean you want to be able to edit the system's voice mails and AA.
Feature 983
The default password is 102000 for two digit extensions, 1020000 for three digit extensions.
Apr 17, 2014 | Nortel T7316E 2-Line Corded Phone
Is there a way to setup caller id on a Nortel system that show when the phone rings
In system programming, you can select whether the display is the name, number, or line.
F**CONFIG
Terminals&Sets
enter extension #
skip Line Access, Capabilities, Name, User Preferences
Telco Features
skip Feature Assign
at 1StDisplay use CHANGE softkey to toggle to NAME.
Mar 26, 2014 | Nortel Lands Phones
New phone - plug in, know what the extension is, how do I know what the direct line is?
If you want to know the extensions number of your phone of any information about the programed feature on any button you just click on feature (button with nortel logo) then * then 0 then the button and it will give the information about the button. For extension you should use the intercom button which is normally last button on the buttom of your rigth hand side.
Jan 07, 2013 | Nortel Norstar 16-Line PBX Speakerphone
All of a sudden the line lights on our nortel switch Meridian M7310 phones started blinking and the lines are dead. Any ideas?
If you only have one line,why not just lose the Nortel system? You can reuse the wiring from the phone sets to the contoller as regular inside wire,and just plug in regular phones(and maybe put the Nortel phones and controller on EBay and make a few bucks off it!)
Oct 26, 2012 | NorStar Meridian M7310 Phone
How do we unrestrict long distant calls nortel t7316e
i got this from Nortel expert and it works:
- press feature **266344
- user ID: 738662 Press ok
- Password: 266344 Press ok
Terminal & Extensions will appear
- press Call Timer button 1 time
write your extension or the extension you need to configure
or press find till you find the extension you need
- press Ring Again button 4 times
Restrictions will appear on the screen
Restrn Filter will appear
- press Ring Again button 1 times
Filters will appear
Normal 02 will appear ( it can be any 2 numbers)
- press CHANGE which appears on the screen
Type 00
and then press the end call button
Jan 12, 2012 | Nortel T7316E 2-Line Corded Phone
Unable to see if an internal extension is engaged
It doesn't exactly work that way, but you can program the extensions back under the buttons. Pick a button that you want to save an extension under and press FEAT *2 the button and dial the 2 or 3 digit extension number. Now the button monitors the status of the extension. It will light whether it's in DND, or busy on an outside or internal call.
Carl
May 21, 2009 | Nortel T7316E 2-Line Corded Phone
Change extension number on Nortel T7316E model
Well ~ eagleeigh731 has it mostly correct, do what he said to do and get into the programming --> find SYSTEM PRGRAMMING --> hit next until you find CHANGE DNs--> OLD DNs (this is the old extn#) 222 then type in NEW DN 431--> then hit the end or release button.
Voila your new extension is now there... to check dial FEATURE 0 then press the intercom button, the new extension should be there.
Mar 17, 2009 | Nortel T7316E 2-Line Corded Phone
is it a bcm 50?bcm 50 must be version 3.0 release for module to work.
Dec 09, 2008 | Nortel 1140E
Lands Phones Logo
67 people viewed this question
Top Nortel Lands Phones Experts
martin hogg
pbxinc
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
