Everytime a wireless unit goes bad it seems to be at night. Batteries are not replaceable. I rarely use this system, I just want to remove as they go bad.
Before deleting the current program and reprogramming your NX-8 wireless smoke detector, you may want to try the following troubleshooting steps:
Check the batteries: Ensure that the batteries in your wireless smoke detector are not dead or low. Replace the batteries if necessary.
Check the signal strength: Make sure that the wireless smoke detector is within range of the NX-8 control panel. You can try moving the detector closer to the panel to see if it helps.
Check for interference: Interference from other wireless devices, metal objects, or thick walls can affect the signal strength. Try removing any potential sources of interference or relocating the detector.
If these steps do not resolve the issue, then deleting the current program and reprogramming the wireless smoke detector may be the next step. Be sure to follow the instructions in the NX-8 programming guide to properly delete and reprogram the detector. If you are not comfortable with programming the system yourself, you may want to contact a professional alarm company or technician for assistance.
I am sure there is separate programming for each zone. You will need the manual for the system. Probably can get it on line. This chime feature usually comes from the factory with no zones programmed for reporting. Hope this helps
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
This could be referring to your battery backup for the control panel. Make sure your battery connections are secure and check the batteries' voltage with a multimeter. If it is showing less than 12 volts and has been connected to the control panel for more than 24 hours, the battery is bad and needs replacement. Contact your local alarm company and ask them verify the battery is bad, and they can install a new one for you right then.
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
This sometimes can also be related to the internal batteries in the alarm ECU or alarm siren module going bad. If your handy the internal batteries can be replaced without buying a new replacement unit. Otherwise, the entire module must be replaced ($$$). Lastly, you can have a Saab indy or dealer disarm the theft alarm on the vehicle. You retain your keyless operation, but the alarm is not active. This is done in the programming and adjustment menus in the TWICE unit with the Saab Tech 2 computer. Justin Duthie Strictly Saab Melbourne, FL
