Question about Frigidaire Ovens
Set the clock on Frigidaire mmodel # ffcm1155us
Posted by aurora guerrero on
ray gallant
    Top Expert:
  • Frigidaire Master
  • 67,926 Answers
PRESS CLOCK THE USE UP/DOWN BUTTONS TO SET TIME THEN PRESS TIME AGAIN
Posted on Jan 10, 2019
How to set clock on frigidaire fpbm3077rfb
To access the clock controls, press the "Stop clear" button, press "User pref," and then press "5." Use the number keys to enter the time as a four-digit number. For example, press the "1," "2," "3," and "0" buttons to set the clock to display 12:30. Press "Start enter +30 sec" to complete the process.
Oct 09, 2017 | Frigidaire Ovens
Why can't i set the temperature on my frigidaire oven model # FFGF3053LSC? Burners work. I have unplugged it and plugged it back in. I have checked the circuit breakers. It still does not work. ...
Good Afternoon Annette,
I see that you are having trouble setting the temperature on your Frigidaire oven, model# FFGF3053LSC, even after resetting it by unplugging it. First I would make sure that you are able to set the clock as well. Try setting the clock by pressing the clock button and then pressing and holding down the up or down arrows to change the time. If you are able to do this and not set your oven, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why you are unable to set the temperature for your oven. Hope this helps.
-Best Regards-
WP
Apr 25, 2014 | Frigidaire Ovens
Don't know how to set clock on frigidaire range model # RG94BF*0 please help
There are 3 knobs below time display and one to the right.
Push the right 2 buttons at the same time while turning the right knob to set time..
Apr 06, 2011 | Frigidaire Ovens
I have a Frigidaire Range model PLES389DCC, it's top cooking function well, but display panel PF show, the clock start from 12:00 (after off/on circuit breaker) and kicking. I have order the control panel...
The clock may be set for 12 or 24 hour time of day operation.
The clock has been preset at the factory for 12
hour operation. When the range is first plugged in or when
the power supply to the range has been interrupted, the
timer in the display will flash and PF (power failure) will
appear in the display.
To set the clock:
1. Press Clock . "CLO" will appear in the display.
2. Example for 1:30. Press the numbers 1 3 0 to
set the time of day to 1:30. "CLO" will disappear
after 4 seconds and the clock will start. Or you may
press Start. "CLO" will disappear and the clock will
start.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 29, 2010 | Frigidaire Ovens
Frigidaire professional stove, Oven does not work, can't bake, self clean. get an ERR F30 code.
Is the clock set?
In mine - the clock has to be set - or it won't work;
Aug 12, 2010 | Frigidaire Ovens
How do you set the clock
You didn't mention a model number. If you have a touchpad, press clock turn temperature control up or down. When the correct time is set, press clock again.
Apr 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Unable to set clock upon installation. Unit has a button
Hold in the button for a few seconds and the numbers will flash. Then use the up or down arrow. Should do it for u. good luck
Feb 05, 2009 | Frigidaire FGB24T3E Gas Double Oven
Frigidaire free standing range
Please post the model number for he stove in question. Its harder to advise without it.
regards
Nov 21, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Fault Code F1
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
Ovens Logo
510 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Ekse
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
