Kenwood KDC-MP235 CD Player Logo
Posted on Aug 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Aux problem when i connected the cable from ipod to aux jack on front of stereo....nothing happens....cd and tuner and standby work but not aux.
Anonymous
Level 2:
  • Expert 227 Answers
  • Posted on Aug 05, 2009
Anonymous
Expert
Level 2:
Answers
227
Questions
Helped
129673
Points
816
You have to go into the standby menu and turn aux on. Go to standby, push menu button and scroll down to aux and turn on
2answers
tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 • Apple iPod touch
1helpful
4answers
How do I hook up my ipod to my pioneer vsx d409 ?
The best way is to use a 3,5mm stereo jack to 2 RCA cable like this:
You can easily find one like this at your local audio/electronics shop or buy one on line. You have to connect the RCA at any free stereo input at the back of your Pioneer (like aux or cd). Take a look at this picture:
After this you can use the 3.5mm stereo jack for connecting not only your ipod but every mp3 player or other device has an earphone jack. Just plug the 3.5mm jack at the earphone jack and rise the volume at the portable device up to the middle of the volume range and set your Pioneer input selector at the stereo input that you connect the 2 RCA before (aux or cd)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
The battery on my car ent dead and now my AIWA CDC-MP32 keeps displaying "please unplug auxillary plugs"
An auxiliary input allows you to select an external source and play it through the cd player's amplifier. It's often used for iPods and MP-3 players. Typically you just need an inexpensive patch cable that connects the headphone output from your portable player to the input on the CD player. After that you can select "AUX" as another source like CD or Tuner, and whatever's playing on the portable unit will be heard through the speakers.
Auxiliary inputs can be on the front or the rear of the CD player. Front aux inputs are typically 3.5mm stereo plugs, similar to a small headphone jack. Rear aux inputs can be RCA jacks or a 3.5mm jack. If you have a CD player with a rear aux input, a cable needs to be connected at the time of installation. Then the other end can be routed to whatever location in the vehicle you want to keep your portable player while you're using it with the CD player.
Front aux jacks are more convenient for quick connecting/disconnecting the portable player, but they tend to wear out over time.
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
1helpful
2answers
How do you hook up your ipod through the rca cable hookups in the back without the radio still playing?
This is different on every stereo, but generally the RCA ports in the back of the stereo are labeled "Aux" or something to that extent.
First, you must purchase a headphone jack to RCA cable which can connect to both your stereo and your ipod.
Connect the cable, turn your ipod on and start playing a song. Turn the volume on the stereo to a moderate volume so you can hear when the song is being played through your stereo. Then, using the selector switch, turn the stereo from "Radio" to "Aux" or whatever it says next to the the RCA plug ins on the back.
I have a CDE-9872 and it wont pick up my ipod touch
Add Alpine's optional "Full Speed" connection cable and you'll be able to use the CDE-9872 to control your iPod. -Crutchfields website
This is compatible with first and second generation iPods touch.
fyi- if you have a mini-stereo aux in jack on the deck you can connect a ipod touch compatible mini stereo cable to the earphone jack of your ipod.
5helpful
3answers
Ipos nano 3
It will work bu tonly after enabling the aux jack.
Place unit in standby mode then press menu for a second and then goto aux and select it to aux on1
Hook up IPOD
I am not sure if the model you have supports iPod control, but if it has an input jack in the front, you can use a cable from the headphone jack into the Aux jack in the front of the stereo and when there is a cable inserted into the jack you will be able to select Aux with the source button.
The other option is to get a kit installed at your car stereo place that will allow you to connect it via 3rd party hardware.
Cheers
3answers
3helpful
3answers
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
