Need to keep kid from turning her cartoon off how do u lock screen
SOURCE: I need a users guide for the acer iconia tab a500
Hi Cari,
I am including the direct link for the user guide below. The user guide is around 10.5MB in size.
http://global-download.acer.com/GDFiles/Document/User%20Manual/User%20Manual_Acer_1.0_A_A.pdf?acerid=634558081604921091&Step1=Tablet&Step2=ICONIA%20TAB&Step3=A500&OS=a08&LC=en&BC=Acer&SC=PA_6
If that link doesn't work, try the below link.
But you will have to select the product manually.
Go to Tablet>ICONIA TAB>A500>Select Document
The user manual is the last one listed.
Hope that helps.
SOURCE: I turn on my Acer iconia w501p but nothing happens... Someone can help me?
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
To disable guided access try the following:
Triple-click the Home button and enter the passcode chosen during setup of Guided Access to unlock the device
You'll now be back to the usual behavior of iOS.
If you'd like to turn off Guided Access completely, just go back to Settings > Accessibility > Guided Access > and flip the setting to OFF. You'll need to enter the passcode again to do so.
SOURCE: how to switch off the demo mode of a tablet acer iconia b-1 710
Have you tried contacting tech support, its possible it will only take a minute or two and they may even steer you in the right direction to download a guide.
