Take a rag and put over nut then tap all-around nut. Then use your hand to try and unscrew. A strap wrench is the best tool for taking these off. I have been to so many of these where the homeowners have used channel locks or pipe wrenches and scarred up nut or broken off copper tubes. They seem amazed when i tap it a few times and remove it with my hands. Channel locks and pipe wrenches actually cause the nut to bind when using this much force. Make sure you loosen the plastic retainer on top of the nut first.
For more details about single faucet repair
SOURCE: Adjusting single leaver faucet handle
The little wrench tightens the tension ring that fits on the inside of the retaining nut right under the handle. You fit the little "arms" in the notches.
SOURCE: replace delta single handle shower cylinder
Yes, I believe this unit uses a cartridge right? They do fit a little tight due to the small washers on the back side of the cartridge. If this is the one I'm thinking of, there are two leg like appendenges that come off the back and fit into small holes at the back of the manifold or what some call mixing valve housing.
SOURCE: Delta single handle kitchen sink faucet
Tuen the stops off unsder the sink . Remove the alaen screw from the handle. Using a spanner wrinch or a needle nosed pliers spred apart unscrew the large nut that has two slots. Lift the whole assembly out. Take assembly to the plunmbign supply and match ius the kit that youy need with has two new rubber seals and two springs and maybe a new spanner nut. It also comes with the spanner wrench and allen wrench needed to renstall. Tip you may be able just to tighten the spanner nut(clockwise) and stop the leak w/o rebuilding it.
SOURCE: delta single handle faucet leaks
BEHIND THE HANDLE THERE SHOULD BE A SET SCREW THAT HOLDS THE HANDLE ON THE STEM. THE SET SCREW WILL BE BEHIND THE LONGEST PART OF THE HANDLE LOOK AROUND BACK OF THE HANDLE. AFTER REMOVING THE HANDLA THERE WILL BE A STEM AND A NUT THAT HOLDS THE ASSEMBLY IN THE HOUSING
SOURCE: leaking hot water from delta single handle facuet
when the handle is in the 12 oclock position you should see a set screw. Loosen and it should come right off.
A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
