Question about The Computers & Internet
SOURCE: monitor power light is blinking .but monitor is not displaying anything
We had the same problem with a Princeton VL1918 19" LCD monitor. Usually its a capacitor problem. If this is the case you might need to take the monitor apart look on the power board for the bulged capacitors and pull the numbers off of the caps. Go to a radio shack or find an electronics store in your area, get a soldering gun a soldering vaccum bulb and a wet sponge. Make sure you plug the right post into the right hole before you solder it. There is a Negative and a Positive on the caps. The wafer board should say where the negative whole is, also the capacitors on the board will show a negative side. Just use a pen or a sharpie mark for the negative posts, there may be a few caps that may be bulged. On the Princeton I just fixed it had three of the same capacitors 470uf at 25volts. Make sure you get the right caps or you have the potential to mess your monitor up even more than it already is. Inspect all your caps on your power board, Im sure there will be some rather larger ones and some small ones, if they look bad or you even suspect them of being bad REPLACE THEM. Capacitors are CHEAP so replace them if you suspect them of being bad. Solder new caps onto the board and then clip the extra cap posts. A note on safety. PLEASE BE SAFE DESOLDERING OLD CAPS. They can be charged in some cases. Just don't cross the posts when desoldering. The new ones that are packaged should not be charged but safety first ALWAYS assume a capacitor IS charged at all times! You will live longer if you take that approach!
Posted on Nov 18, 2008
Fond one solution I think.
http://74.125.47.132/search?q=cache:6eHC9Y38fx4J:josepino.com/other_projects/%3Fhowto-repair-dell.jpc+Dell+E172FP+monitor+repair+transistors&hl=en&ct=clnk&cd=3&gl=us&client=safari
Posted on Feb 01, 2009
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
The internal circuits are jammed because of electrostatic charges
accumulating on capacitors, or because of a wrong voltage read by the
main chip on your monitor controller board. this started the protection
circuit.
2 The protection circuit detected a wrong voltage or a
broken contact, identified an internal fault and kicked in , starting
the flashing light.
If you are in situation one, then the
monitor will reset just unplugging power cord for one or two hours,
sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common
faults that can occurr suddenly are a blown capacitor on power board,
the inverter board powering up backlight lamp has blown, or a fault on
main lcd controller board.
check also the video cable, if the cable
is shorting, or the connector is bad, you can get same flashing state
because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact manufacturer to find out a service point.
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Posted on Mar 06, 2009
SOURCE: Trying to replace the battery
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery hope this helps you and please vote for me
Posted on Dec 04, 2010
