Question about Maytag Refrigerators
Ice maker for maytag # MF12269VEW4 how to remove to repair
Posted by James Moir on
5 Related Answers
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: maytag ice maker flap keeps opening like it was possessed
If the flap your mentioning is the one that opens and closes that is on the freezer door,than it needs to be replaced with the "Fountain Kit ".In this kit you will have the parts that control this problem.Replace ALL the parts that are in this kit with the parts off your old one.If installed correctly ,the problem is fixed.
Posted on May 12, 2008
peyton32034
peyton thompson
  • 410 Answers
SOURCE: Ice maker removal
first of all remove the ice bucket. then you will see a wiring cover on teh left hand wall just below teh icemaket. there is a rectangular hole in this cover. using a small precision scredriver carefullly insert into this hole and push up or and down to release a hidden clip. the trick is to pull on the wiring cover while you try to maneuver the clip. first time you do it it can be very frustrating but keep working at it and you will get it.
alternately you could just leave the Icemaker in place and use a hairdryer to melt the jammed ie out of the way. good luck peyton
Posted on Jan 28, 2009
Anonymous
  • 242 Answers
SOURCE: Water wont fill ice maker
the relay is the ice maker , buy the kit that contains the valve and it is a complete new ice maker system.
easy to find at sears parts.
Phil
Posted on Jun 11, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Maytag Ice Maker do not work
No your model has a module that if defective you will need to replace part number D7824706Q But we are not sure yet so I want you to fill with tap water and turnon and if the the ice freezes and dumps normally into ice bin then it is possible that the water control valve for ice maker side is defective. please try that first and let me know, Thanks, Sea breeze
Posted on Apr 08, 2010
Testimonial: "Thank for your help. Very specific and ilustrative your explanation."
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my maytag refrigerator sidebyside ice maker stop working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnc
Posted on Sep 30, 2010
Ice not dispensing through the door and I dont hear a motor
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Question: Kenmore Refrigerator Will Not Dispense Ice Through the Door. My Kenmore... I don't hear the motor or the crushed ice. What do I do? I have a nearly ...
Ice maker is not dispensing - Checking auger motor & ice ...
? 5:33
https://www.youtube.com/watch?v=Uk83V-fA8Pk
Jul 1, 2013 - Uploaded by ApplianceVideo.com
Ice maker is not dispensing - Checking auger motor & icebucket - Maytag, Whirlpool MSD2550VE502 ... Don't like this video? Sign in to ... The Geek - Maytag French Door IceMaker Replacement - Duration: 25:28.
Ice Dispenser Repair Guide - Appliance Repair Guide
www.appliance-repair-it.com/ice-dispenser.html
Feb 09, 2016 | Refrigerators
I have a Maytag MFI2568AEW refrig. and the ice maker is not filling up. I checked the dual water valve and it is not getting power to open the solenoid valve with the ice maker switch on and the ice bin...
On typical ice makers that signal comes from within the ice maker. It sends a signal from the ice makers thermostat and the ice maker begins to pre-heat the ice cube slots and the ice rake begins turning to push the ice out of the slot's and into the ice bin. The last function is to refill the water with a signal to the dual water control valve that last about 7.5 seconds. Once the ice maker senses the water is frozen again it begins this cycle again. Here is a refrigerator parts PDF for your model=> MFI2568AEW and on page 10 you will see part=> 627985 Pin Style Icemaker Thermostat
Adhesive - Alumilastic (Cement)
That is just silicone rubber you can also get locally. If you have any other questions please let me know, Thanks, Sea Breeze
Y13068002 or Repair Clinic 1266731 Ice Maker Assembly
Feb 17, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
The ice cube maker is leaking How do I shut it off?
Good day,
If the water continues to run into the the ice maker even though the ice maker is not cycling, then the water valve in the bottom rear of the machine has failed.
To stop the leak, you would need to shut off the water supply from the house.
To repair it so the ice maker would work, you would need to replace the valve assembly. It is a non-repairable item.
Changing the valve is not difficult and most any appliance parts house would carry it. Take the model number with you, or the valve if you have removed it.
Sep 11, 2010 | Maytag Refrigerators
My ice maker quit working when I replaced the water filter.
Your model Maytag comes with an electronic ice maker and if you just recently changed the water filter the water should be dispensed for 2 or 3 minutes or until any air that may be trapped in the lines is removed. If air is sill present in the filter the ice maker opens the water control valve for about 7.5 seconds. If air that is what the ice maker will get until the air is completely purged from the system. If you fill that you have past that point then pour tap water into the ice maker and let freeze. After the water freezes the ice maker should cycle and dump. If not the the ice maker core may need replaced. If yes it dumps then the air may not yet purged or the water control valve for the ice maker side may be defective. This is one of those wait and see repairs. I will send you a link to the copy of the service manual and page 71 begins addressing the ice maker. Thanks, Sea Breeze
Dec 22, 2009 | Maytag MSD2650H Side by Side Refrigerator
Ice maker has ice in the tray, but will not dump or do anything
"Ice in the tray". Do you mean ice is in the well of the ice maker, or in the tray or bucket that collects the harvested cubes from the ice maker?
If the problem is the ice is in the ice maker well, and will not dump, then, if the ice maker is turned on, and the temperature in the freezer is 14 degrees or colder then the ice maker has failed.
In rare occasions an ice maker can be repaired but is rarely done, and is a repair only someone with strong working knowledge of ice makers can perform.
If you are handy with tools you can remove the icemaker. 3 screws and power plug. Once out you can check the well to see if something has jammed up the rake, but that's about all.
Oct 28, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
117 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
