Question about Simplicity Vacuums
How do go about replacing on/off switch in my Simplicity 6970? I have ordered part Main Switch A428-2014 as the rocker switch no longer turns the unit off. Thank you!
Posted by Joanne on
Thatvacguy.com
  • Simplicity Master
  • 1,604 Answers
Remove the handle screw to remove the handle assembly from the vacuum. Remove the screws holding both sides of handle together to separate handle to get access to switch
Posted on Feb 24, 2019
5 Related Answers
Anonymous
  • 625 Answers
SOURCE: rocker switch for 600 watts broken----
First of all complaining to FixYa isn't going to accomplish anything. I doubt that the supplier of your device even knows about FixYa. Now on to your problem --- can you get me any numbers off the rocker switch? I'll do the research and get back to you. Use my original email address which can be found in my profile.
Posted on Dec 06, 2007
Anonymous
SOURCE: Need to replace switch but can't find replacement
An update: Grainger has several fan controls with the same 10A capacity as the one you're looking to replace: http://www.grainger.com/Grainger/categories/hvacr/controls/fan-speed-control
Posted on Aug 24, 2008
Anonymous
  • 4 Answers
SOURCE: Power switch
If it looks like this you can get one here.
Defond DRH-2415 15A 125VAC Lighted Dual Heater Switch
Posted on Jan 14, 2009
Anonymous
SOURCE: Euro-Pro Steam Generator EP8015 - Rocker switch
The screws holding the unit together are T-20 TORX screws; the center post makes them anti-tamper TORX screws. These screws are used in applications in which the manufacturer does not want the average consumer to attempt repairs. Please don't take this wrong, but if you have to ask about the "unusual 6-sided screw", then you shouldn't be opening the unit.
Unfortunately, when the heating element rocker switch gives out (3-4 years), it is usually about time to overhaul the entire iron (both the tank portion as well as the iron portion). Other things that can cause problems are the thermostat and the pressure actuator.
Contact A2A Consulting at 1-888-830-3563; they can probably fix the unit for you.
Posted on Feb 03, 2009
Anonymous
  • 430 Answers
SOURCE: My Electrolux Epic 6500 SR will not turn off by
WOW !!! Finally You are dead on, absolutely 100%.... good work!!!.
Get only a genuine new switch button with spring from an AERUS Electrolux dealer and reinstall.
Then carefully reassemble the entire body and wiring harness.
Congratulations getting there.... you rate as an honorary technical genius in my book,...Your wife should be bragging about you to her friends. I am genuinely impressed and I`ve been fixing these since 1990. I bow in your presence.
PS while youre in there, check the rocker for evidence of fatigue, it is the more common issue
Posted on Nov 01, 2009
Testimonial: "Thanks for your speedy reply and diagnosis. I will get the operator button and also the rocker part while I am at it. "
Where camN I buy replacement on/ off rocker switch ?
rocker switches are usually fairly universal ace hardware may have one or you can order it from the MFG
May 13, 2014 | Tristar SB Steam Buggy Vacuum
Model 6970 will not start have checked all hoses tried to locate reset button by sticker on back of machine; where is it?
The reset button is the little white button (approx. 1/16" inch wide) by the sticker.
Mar 24, 2011 | Simplicity Vacuums
How do you replace switch on Epic 6500 vaccum
You may need a ROCKER device for the switch, however before you go there determine if you can hear an audible click when depressing the switch, or if the switch just springs up and down with no click.
A click means a rocker is needed. No click, just springing up and down with an occasional click means the spring attached to the underside of the switch button is fatigued, you need the button and switch mechanism, same location but above the rocker.
Also post the issue. If the lights are on and the vac won't start or stop, the switch is the problem area. If it starts and shuts off with the bag full light on it is more likely the control valve. If no lights come on your problem is in the cord or rewind and could be a failed rewind spool.
The best and genuine switch parts are best found only at an AERUS Elctrolux store
Look for my post from earlier today and you will have full instructions on opening and checking the control valve and the entire unit.
Post back with results
Dec 23, 2009 | Vacuums
My Electrolux Epic 6500 SR will not turn off by pressing on the switch button. I took it apart and removed the switch assy. I can maunually turn it off & on by pressing the rocker arm on the switch...
Nov 01, 2009 | Electrolux Epic 6500 Vacuum
Replace switch on electrolux 2100
The 2100 is an older model which is prone to rocker switch failure. What you see outside is only a switch button. Underneath is a plastic rocker which sits in a grove and pivots back and forth to activate the on off switch.
If you push the switch down and there is no audible "click" you Likely need the rocker itself, especially if you tip the vac upside down and shake it and hear a piece rattling inside or find a broken narrow plastic finger about 1/2" inch long when opened.
However if it clicks and works every 3-5 times,the rocker is fine and you will need the spring mechanism and switch button which you can see form outside.
To remove either the process is the same.
Separate the body by opening the bag cage and pulling the two bumpers forward with a set of pliers. They are locking keys. Once removed, the rear housing will drop off allowing the vac to hinge open back to front. Do this with the vac laying upside down and observe the hinge section of the front bag door .DO NOT REMOVE THE MOTOR. You will need to clip all these componnets back together to reassemble and slide the bag chamber back to seat against the motor with the motor housing engage in the ribbing of the vac side walls.
With the vac open you will only need to remove the spring loaded bag lockout switch and the bag housing it sits on, not the motor or rewind..
Once removed there will be 6 chrome philips screws visible. These hold the top trim on the front of the vac and the front ones hold the on off switch into its housing. At the very front will be two screws going through a black or whitish switch housing. That housing will lift out with wires attached to reveal the switch rocker, etc,. This portion will lift back and out at about 45 degrees of the inner housing, as a unit. The switch button sits atop the rocker via two end tabs and will pop off the housing to reveal if the rocker itself has a broken "finger" or if the button has a weak spring.
The suspect spring is not the coil rocker spring but the thin U shaped spring on the underside of the switch button. Remove the rocker spring with a pair of needle nose pliers.and examine the rocker comparing to your new one.Use more vaseline on the new rocker and if you have it reinsert the clear flex plastic into the coil spring. If not disregard.
Re-installation is the reverse order, tuck switch back in at 45 degrees from back to front.
Pay special attention the the rubber seal at the back of the bag cage.
If anything is misaligned in this body you will fight to reassemble. Don't fight it , back up and look at your work. When and ONLY when it is perfect it will realign and click together like a lego set and the keys will slide in perfectly
You can and should test the vac before reassembling the whole body, simpley slide your hand under neath and activate the switch, with a bag inside the vac.
See now, wasn't that EASY???????
Please post back to advise how you make out. Its a 7 minute process worth $25 for a good tech. A bad tech will spend half a day trying to figure this one out but just go slow and follow the instructions and you will do fine.
Oct 17, 2009 | Electrolux UltraLux 2000 Bagged Canister...
The on/off switch won't click in either direction.
If this is the switch on the hose the switch can pop out the front for inspection. If it is the switch on the vac the rear housing of the vac needs to be removed to access the actual rocker switch underneath the switch pad. Both are inexpensive. If the vac is in good shape check the switch and replace if necessary.
Sep 01, 2009 | Kenmore Vacuums
Replace power switch - Electrolux Epic series 6500
well, i post an answer in the wrong field, and i can't find it, so i will type one more time.
slide two vinyl side pieces off, and remove top halves. remove two screws from the switch, and remove it from top halve. between switch and outside button is a plastic rocker, which is broken. you will find two broken pieces, one spring for the rocker piece, and one small plastic rod, which goes inside of the spring for support. i do not know if part is available, but you can for quick fix like me, turn the switch on by the hand, assemble unit, and plug in, and plug out from the wall. whay? i dont have electrolux store close by.
john
Feb 21, 2009 | Electrolux Epic 6500 Vacuum
Need switch for a shop vac modle qpl650
Ok - heres my story - QPL650 crapped out mid job, checked this post, ordered the switch on the link here, didn't work.
Called Shop Vac, priced a power unit assembley ($82), took the motor apart and traced the orange wires into small junction box, replaced the little rod connecting the contacts with a 1/2" of coat hanger (white paint scaped off first) and I am back in business.
Now I am thinking $82 invested in an index fund at 6% per annum for 20 years is...................
Dec 12, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Shop vac QPL625 on off switch stays on.
Contact Digi-Key 1-800-344-4539 or 218-681-6674 ask for part number EG1505-ND.
Cost is about $2.00 plus shipping.
See http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=EG1505-ND for part details.
You want a D.P.S.T (On/Off) mini-rocker switch.
Apr 16, 2008 | Vacuums
Vacuums Logo
121 people viewed this question
Top Simplicity Vacuums Experts
ray gallant
William Wright
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
