Question about Whirlpool Washing Machines
Printed instructions for installing Whirlpool stacking kit. Can I download instructions for installing stacking brackets on Whirlpool mode WFW75HEFW
Posted by Richard Thompson on
5 Related Answers
Anonymous
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Posted on Jun 30, 2008
Anonymous
  • 29 Answers
SOURCE: do the dryer feet need
YOU WILL NEED TO PURCHASE A STACKING KIT FOR THIS. INSTRUCTIONS INCLUDED AND SIMPLE TO SET UP.
Posted on Jan 28, 2009
Anonymous
  • 4 Answers
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Posted on May 30, 2009
Anonymous
  • 39 Answers
SOURCE: I need the installation instructions
Here is a link for you that may have what you need.
http://www.bosch-home.com/Files/Bosch/Us/us_en/Document/Installation_Instructions/Basic%20Stacking%20Kit_Bosch%20Inst%20Inst.pdf
Posted on Aug 25, 2011
Sal De
  • 2699 Answers
SOURCE: install whirlpool starter/relay kit
you should of ordered part number 8201786 and this is the whole start device that slides onto the compressor,this replaces the overload and relay and it's around 60 dollars. http://www.searspartsdirect.com/partsdirect/part-number/8201786/0046/106?pathTaken=directMatch&filterPart=&pop=flush&prst=0&shdPart=8201786 unplug it,pop the clip off and remove the cover,slide off the device,read instructions, wire it,slide the device onto the three pins on the compressor,put the cover and clip back on and you're done.hope this helps and good luck with your machine
Posted on Nov 17, 2011
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool washer model # WED9270XW1? If yes, what stacking kit do I need to use? Can I stack a new whirlpool washer model # WFW72HED
As we could see new one are not compatible with older one as size and dimension of new washer are changed but in case you could try .It is simple just try compatibility of your older washer stack kit with new one in most new model
1helpful
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
How to stack dryer LEQ1442ES1 and what stack kit to buy?
Hello Friend, that's a great question!
The recommended stacking kit for your Frigidaire dryer (LEQ1442ES1) is part number STACKIT2. Further information regarding the stacking kit and directions can be found in the installation instructions listed below. Hope this helps! - Z
Frigidaire Manual Search Results
18helpful
3answers
Can the Whirlpool Duets stack?
The simple, short answer is yes, the Whirlpool Duet washer and dryers can be stacked. You'll need to check with the Whirlpool folks to see if you'll need a stacking kit, or if they are ready to go with what you already have.
The key to stacking these Duet laundry pairs, is to have both the washer and dryer model numbers when you contact Whirlpool, so they can provide you with the stacking kit needed to mount the dryer on top of the washer. You can also check the Whirlpool web site to get a good idea of how much space is needed for a stacked set. Here's the link for the space checker, just look under the Guides and Tools on the left side and click on the Laundry Space Sizer to see what's needed.
http://www.whirlpool.com/catalog/category.jsp?cat=115
You can also call Whirlpool at (866) 698-2538 and speak to them about your particular washer and dryer.
Hope you find this Very Helpful and best regards!
1helpful
7helpful
4helpful
2answers
Stacking Instructions
You will need a stacking kit 5303937141 to stack them, Feel free to ask for any more advice.
Washing Machines Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
