Question about Karcher Garden
Karcher k3.6 jubilee was washing yard tarmac with vasrio power head all ok stopped for break cannot get power back on checked all connections
Posted by Desmond Glover on
5 Related Answers
Martin Grech
  • 94 Answers
SOURCE: karcher washer went dead
Dear jimbocom,
The problem is that the spill valve got stuck. When the machine is working and the gun is closed, a valve( spill valve) moves with the accumilated pressure and switches the machine off. So what happened is that when the spill valve did its job, it found no water...and remained stuck. This leaving the machine in an off position. Service and lubrication to the spill valve must be done or completely replacing with a new spill valve. In my opinion you have no serious damage, but this job must be carried out by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
Anonymous
  • 174 Answers
SOURCE: Karcher K2.94 Overheats
Well, there is a switch inside. It is controlled by the valve that allows the pump to go into bypass when you let go of the trigger. This switch may be worn out or the valve that controls it is sticking. It may also be that your motor is just worn out. There is a heat sensor inside the motor (you cannot get to it) that sometimes wears out and trips too easily.
Posted on Jun 23, 2009
Anonymous
SOURCE: Manual needed for K3.65 Jubilee Karcher
hi here is the link for manual
http://www.karcher.com/int/Service/usermanuals.htm?translationmode=&ACTION=SELECTTEILENR&ID=16017510&SELECT=Select+Product
Posted on Apr 09, 2010
shaun dolman
  • 68 Answers
SOURCE: Hi My karcher k3.65 jubilee is leaking water when
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Posted on Jun 11, 2010
emissionwiz
Marvin
  • 85239 Answers
SOURCE: y Karcher pressure washer has stopped suddeny. Have checked the power supply to the washer is ok. Pritam
It is likely the motor has failed.
Posted on May 22, 2018
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
Karcher 1600 pressure washer will not get power. It was working then stopped getting power. It is not that old.
ok im a technician... cheak d power swtich. i think most of karcher power knob switch they got a error problem.
May 30, 2011 | Karcher K2.26 Electric Power Washer
1988 Mercedes 300E. None of my power windows work suddenly. Is there another fuse not in the main fuse box? Curiously, the power seats mysteriously stopped working as well but then worked fine when left...
check your buttons lift centerconsole look for bare wires cap or tape up. get buttons at junk yard or try to fix yours get goo gone open switches with small flat head clean springs and ball bearing. be gentle plastic insides break easy these switches break all the tim e go to junk yard and stock your pockets full
Sep 11, 2010 | 1988 Mercedes-Benz 300
Hi My karcher k3.65 jubilee is leaking water when the pump is switched off from underneath
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
I can use my Karcher K3 jet wash as long as i hold trigger down
Most pressure washers have ball lock type fittings on the hose connections. What happens is the little steel balls get a bit of corrosion and do not lock the male fitting properly with the female coupling. Load up the fitting with some Oil or WD 40. Then connect and disconnect the fitting several times to losen up the balls and springs. Should the spring in the coupling break you will get the exact symptom your describing.
If the OIL / WD 40 does not do the trick then you may have to change out the quick disconnect coupling.
Kelly
Apr 18, 2010 | Karcher PSI Electric Pressure Washer
How to connect the cold water supply to K 3.65 Jubilee? In the instruction leaflet, figure J, number 1, 2, and 3 I seem unable to connect it. The above is a pressure washer.
Hi all you need is a 3/4 tap fitting from a diy store.
Maybe a hoselock 3/4 male and female fitting that will fit a standard 1/2" hosepipe. If struggling I can send you a link to the fitting on ebay but if you type in karcher tap connector you will see it by the seller vavcandwash.
Feb 14, 2010 | Karcher 1750 psi Electric Pressure Washer
Jun 12, 2009 | Karcher K2.26 Electric Power Washer
Karcher k7.91 pressure washer /loss of pressure
if the motor will not turn on ,thers a problem with the current excess switch , which is situated under the main power on of swith hi needs to be replced
May 04, 2009 | Karcher PSI Electric Pressure Washer
Hotpoint ultima wt746 error f-12
Just had F-12 on my Hotpoint Aquarius washing machine. Problem was due to water not draining. Power off. My machine has access plate at bottom on the back. The water drain is held onto the drum via a jubilee clip and when i took it off the drain was clogged with hair, sweet wrappers, money, hair bobbles Once cleared, put back as was - machine now running ok..
Nov 03, 2008 | Washing Machines
Garden Logo
43 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
