Computers & Internet Logo
Question about Medion Computers & Internet
I have a Medion MT22. Major problem. It won't turn on. Keyboard flicks on then off and then nothing. Thanks in advance.
Posted by Muriel Grieve on
1 Related Answer
Anonymous
SOURCE: Medion MIM2120 Laptop
Remove the large panel (7 screws) on the base of the machine.
The memory is situated under a black flexible plastic cover about 75 x 30 mm - amost directly below the earphone and mousepad area.
Memory is held in position by clips at each side - press them outwards and memory card will pop-up.
A second card can be fitted below and slightly higher than the first.
I have just fitted IGb and will probably put in another (max 2GB), - cost about £15.
Hope this is of use.
Posted on Mar 15, 2008
I need an instruction manual for everyday use of my Advent MT22
The MT22 is a rebadged MSI Wind Top AE2220
A PDF User Guide for the Wind Top AE2220 / Advent MT22 can be found here:
http://download2.msi.com/files/downloads/mnu_exe/6657_English.zip
2answers
My medion 95924 keyboard is locked. I am unabe to
Does the keyboard work in Dos mode or when you boot up goto set up and see if you can use keyboard to adjust settings
Medion keyboard keeps freezing
Keyboard freezing is usually an indication of a problem with windows (Usually Spyware or viruses) If you can, download Malwarebytes from download.com and see if it helps
I need a replacement keyboard for Medion laptop model no: MAM2100. OR MD 96327.I spilled water on the keyboard, some keys work, some don't. Want to replace the keyboard but cant find one to match. I HAD TO...
Check first for a spare on Ebay, that will be cheaper than buying a new spare, but parts for this model are difficult to find.
For example here is a RAM2000 keyboard, contact Medion to find out if it is compatible:Cybercom MD42792 Medion Ram2000 Replacement Keyboard
If you do not find a compatible part, call medion, they can supply parts and tell you what parts are compatible:Medion.com
Try also Computer parts for MEDION
In US you can also contact Quanta that distributes medion parts internationally, they are locaed in US and ask part price and availability: Contact Us
Medion 2120 stuck on f2 screen
put the cmos battery back in and before you turn it on press and hold down the f2 key should send you to bios where you will have to reset all funcation becase you removed the battery
Keyboard on my Medion MD 40812 PC Notebook will not work
the keyboard needs to be check to see if it is not clip in propery or if the keyboard need to be replaced.
1helpful
4answers
Medion MD41349
You need to remove all the screws from the back also, then remove the cover to the rear on the bottom and remove the wireless card (make note as to connection colours) and there is 2 (I think) screws under there, then one also under the battery, then the whole top opens up.
Make sure you have removed all screws from the bottom case, including the four under the rubber feet at the rear.
This was the most awful laptop I have ever worked on!
2answers
Hi Steve, its kinda hard to advise you considering your limited in what u can do, if you are not able to get into the bios or into safe mode using the keys on the keypad, only thing i would suggest that would be worth checking is the cable for the keypad, to check that just remove the keypad and underneath it there is a cable try taking it out and putting it back in, If the machine lets you into safe mode or bios let me know should be easy enough to fix. And by any chance did your daughter spill anything on the keypad?.. and if you aint sure how to remove keypad just ask will give you more details.. let me know how you get on.. John
Top Medion Computers & Internet Experts
 Mike M
Mike M
Marvin
Marvin
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
