Question about Toshiba Televison & Video
SOURCE: Poor picture quality from 130 degree viewing angle on my LCD tv
It is unfortunate but "off angle" viewing will compromise the picture especially on larger TV's and LCD. Off angle viewing can come from the vertical axis or the horizontal, as you described. This is clearly illustrated with a laptop computer. Adjust the screen forward and back (vertical plane) and you will see very clearly that you get the brightest picture in a very small amount of range of the screen. Likewise, viewing from the side compromises picture as well.
I also don't believe that the delay is indicative of any problems.
Posted on Apr 10, 2008
SOURCE: Remote control code for a Toshiba Regza 46'' LCD TV
0154 0156 0060 1256 0845 0832 1356 0650
Posted on Dec 21, 2008
SOURCE: Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Posted on Apr 30, 2009
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
SOURCE: Sound but no picture
no bulbs to replace here, i might have better news for you. Toshibas with this time frame has an inverter problem. turn tv on tilt back wards at 45degree angle and flack a light to the screen and look closely if you can see the image the replace the inverter units. to help you see hit menu on remote, the menu is white so will make it more visible. If you did want to replace the inverters they are like 60-80 $ for hte pair and simple to replace.
Posted on Apr 27, 2010
