Question about Irons
On my Silhouette 1200 steam iron there are icons. One looks like a rain cloud. What do they mean?
    Top Expert:
  • Irons Master
  • 66,568 Answers
DID YOU NOT READ YOUR MANUAL WHEN YOU GOT IT . IRONING WENT AWAY HERE WHEN THEY CAME OUT WITH WASH AND WEAR CLOTHES DO NOT THINK MY WIFE HAS EVER IRONED ANY THING IN 54 YEARS
Posted on Jan 08, 2019
4 Suggested Answers
Anonymous
  • 137 Answers
SOURCE: melted cordless iron to charging cradle
I don't think there is any saving this iron.
You might try heating it up again to the hottest temp. and pulling it loose, but what would you use for a chargin plate?
Posted on Mar 02, 2009
Ishola Olayemi
  • 1196 Answers
SOURCE: The steam does not work.
Unplug the iron, and allow it to completely cool down before beginning any repairs. Inspect the steam vents from the outside, and use a pipe cleaner or other small utensil to remove any excess buildup that is blocking the vents. Be careful not to let the buildup fall down into the steam vents. Clean the steam iron's directional spray tip. Minerals and other debris can build up on the nozzle over time and will greatly hinder the use of your steam iron. Pour equal parts vinegar and water into the steam iron's water supply tank. Put the steam iron above an empty pot, and turn the iron on. Let it steam the solution until all the water/vinegar solution is gone. Now try use it to see it performance.
Posted on Aug 22, 2011
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: steam boiler iron
you can download instr. manual from www. fitness.manualsonline.com or www.retrevo.com or www.manualsfactory.com
service manual go www.pdfservicemanual.com
God bless you. However see the diagram is universal for repair small appliances.
Posted on Jul 26, 2012
keri rickhuss
  • 5 Answers
SOURCE: Swan SI5042 Steam Generator Iron The standby
Have you fed it with water
Posted on Jul 27, 2014
Iron is producing too much steam. Is the thermostat broken?
Steam Iron Features Explained: The Life Unwrinkled Buyer's ...
lifeunwrinkled.com > Steam Iron Buying Advice
Do more watts mean a better steam iron? Not necessarily, but there is a bit of a range that I like to stick to. I find that some irons have too much power for home ...
Iron, Steam & Money: The Making of the Industrial Revolution
Nov 24, 2015 | Irons
Euro-Pro X
Check the hose for something clogging it. It will be past the flattened area (by that I mean further from the steam cleaner). It sounds like something got stuck in the hose, and as the steam cleaner kept sucking on the hose, it caused the hose to flatten.
Sep 08, 2007 | Euro-Pro Steam Generator EP8001 Iron
Leaking water when I push the trigger to get steam
It sounds like you do not have the heater setting not high enough to provide vaporize the water in the heater tank. Did you adjust the temperature on the main unit to the "cloud" (steam) setting? I would also check when the unit is cold that the reservoir (behind the trim knob is a metal screw (use a penny to remove it) and shake out all water in there. I always use the burst of steam when I am finished to purge the system of all standing water. Also make sure you only use clear filtered drinking water with low mineral content (I use our kitchen Reverse Osmosis 5 stage Water filter in the iron only).
Sep 11, 2011 | Rowenta DG-980 Iron
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
Jul 27, 2011 | Morphy Richards Jet Stream 42271 Iron
We own a SmartLiving Steam Mop, and have really enjoyed it. It suddenly quit steaming. We tried putting vinegar through it in case it was hard water deposits, but no luck. Any siggestions?
yep i have one,,,,,dont use vinegar,,,thats good on chips? no good in steam mops!
go get yourself some kettel cleaner ,,,the stuff for cleaning the lime scale off the inside of your kettel,,,,mix it up in a jug with warm water,,,,and tip that in your steamer,,,dont breath the fumes?
this will clean out any lime scale for you,,,next time fill it with rain water,,,,there is no lime scale in rain water?
Nov 27, 2010 | Hamilton Beach Steam Excel 14770 Iron
What kind of water should be used in a Rowenta Titan Plus
It is always recommended to use distilled water for steam iron in general.
Second best is clean rain water.
For an expensive iron, I would not use Tap water as it has too many residue/mineral that will eventually cause brown/dark stains spots to be ejected from the steam iron pores!
You can buy 'bulk' distilled water for ironing from most supermarket and departmental stores. You can also use pure distilled water for car battery topping but auto shop tend to charge a premium for it!
Hope the information is helpful!
Hope the information is useful.
Sep 24, 2010 | Rowenta Professional DX8800 Iron
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Melted cordless iron to charging cradle
Mar 02, 2009 | Irons
Irons Logo
177 people viewed this question
Top Irons Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
