Question about OKI Office Equipment & Supplies
SOURCE: oki c5200 "Fatal Error 106"
from your service manual....main board issue
Posted on Jan 16, 2008
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: does anyone know what is
If you look on top of the fuser roller(upper orange roller), there is a thermistor (orange rectangle plastic that rides on the roller) you will see four wires going into that housing. Two are for the thermistor and the other two is for the fuse that is built into the housing. You would have to use a soldering iron to melt the plastic that the fuse is sitting in. You would have to figure out what to use as a fast blow fuse.
Okidata makes it difficult to take out the thermistor because the nut is locktite on the screw. Try using the soldering iron to melt it. Just make sure you dont damage the thermistor.
Posted on Jul 03, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
SOURCE: oki c9600 fatal error 175
Error 175
Fuser Thermistor
short-circuit or Open
is detected (High
Temperature (HOT)
or Low Temperature
(COLD))
Turn ON power again.
Leave in that state for 30
minutes then turn ON power
again.
Posted on Mar 29, 2010
Jun 20, 2016 | OKI C Office Equipment & Supplies
Jun 02, 2014 | OKI C7300 Led Printer
Apr 26, 2010 | OKI C5650n LED Laser Printer
Dec 10, 2009 | OKI C5500n Printer
Aug 26, 2009 | Office Equipment & Supplies
Jul 20, 2009 | OKI C5500n Laser Printer
Jun 19, 2009 | OKI C5150n Led Printer
Apr 16, 2009 | OKI C5200n Laser Printer
Mar 15, 2009 | OKI C5100n Laser Printer
Mar 07, 2008 | OKI C5300n Led Printer
80 people viewed this question
