Question about Samsung Heating & Cooling
I need Option Code samsung model:AR18KSFHCWKZAR
Posted by jorge bolaos on
Unlock samsung phone model SCHR630
Brother:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Dec 19, 2012 | Samsung A877 Impression At&t Blue Slider...
Tip
How to find out the series number and model code of a Samsung Smart TV
1. From your Smart Remote press the Menu button
2. In the menu displayed in the TV , select the support option
3. Select Contact Samsung option in the Menu
This displays the Model number / code, firmware version and other details of the TV. Scroll down the popup menu to view other details of your TV.
on Jan 09, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Need unlock code for gravity touch
You can either unlock by cable (cheaper but need to install drivers and need for USB cable) http://www.unlocksamsungonline.com/samsung-T669-unlock-by-cable/
or unlock by IMEI
http://www.unlocksamsungonline.com/samsung-T669-unlock-by-codes/
Important note. your phone model has a bug (from Samsung) if you phone is in 'freeze mode' (which you get after entering wrong unlock code too many times) you can only fix this cable and 'direct unlock' option. 'Read unlock codes' or unlock by IMEI will deliver you correct unfreeze code but the phone will just never accept it.
Jun 29, 2012 | Samsung Gravity Touch T669
Samsungs lock
It's locked to Network or security lock?Security lock means get the master reset code from service provider and unlock it,You need to unlock it from Network lock mean specify the Network and country,Model etc and get the Network unlock code for SAMSUNG phone at here Prounlocking.com/samsung/rs8wp8/ and unlock it.
Dec 10, 2011 | Cell Phones
I changed the debug screen option from medium to high on my samsung pixon 12 and when i start up the phone it freezes
Hello, You will need to reset your phone, for everything to return to normal. On idle screen type this code:*2767*3855# . Once this is done, your new security code will be; 00000000 Due to your phone model, your security code may still remain the same, even after this reset. Enjoy. Hope this helped.
Apr 22, 2011 | Samsung Cell Phones
Give me formate code for samsung C5212
list of samsung codes for u
Quote:
PLEASE BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong
network SIM and insert a half of it,(pic2501)
so it won't ask for
network password and shows "Insert SIM" message.(pic sam25020)
Now put the battery ,and switch the phone on .(phone shows "InsertSIM" message.)
3.With out turn off the phone push the sim fully in. At this stage the phone isstill asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#(star7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable
networklock By typing: #7465625*638*00000000#(hash 7465625 star 638 star8zeros hash)
Phone is unlocked (check with *#7465625#)
For Model:
Samsung A300
*2767*637#
Model: Samsung A400
*2767*637#
Model: Samsung A800
*2767*637#
Model: Samsung E500
*2767*688#
In newer phones:
#*7337#
Model: Samsung E700
*2767*688#
In newer phones:
#*7337#
Model: Samsung E715
Turn off the phone. Put a non-accepted Simcard and turn it on. Type*#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# andhit the Call button. Turn off and insert another Simcard. Turn on. The code is00000000.
In newer phones:
#*7337#
Model: Samsung M100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) untilphone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8digits of the NCK/SPCK)
Model: Samsung P400
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung S100
*2767*7822573738#
Model: Samsung S105
Remove Simcard. Enter *2767*7822573738# and after phone reboots, enter#0111*00000000#
Model: Samsung S300
*2767*7822573738#
Model: Samsung S307
In newer phones:
#*7337#
Model: Samsung S500
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung SGH600
*2767*3855#
*2767*2878#
Model: Samsung SGH2100
*2767*3855#
*2767*2878#
Model: Samsung V200
*2767*7822573738#
Model: Samsung X100
In newer phones:
#*7337#
Model: Samsung X600
In newer phones:
#*7337#
Model: Samsung Universal
TEMPORARY UNLOCK:
Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. Youwill get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
d500 - #*7337# - ( but not in the newer software versions )
update 04/02/07
1. If you have changed your phone password, change your password back to thedefault 8 zeros (00000000).
1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, thenSIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone islocked to
3. When Incorrect SIM error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey.
5. From the menu that appears, select the Malloc Fail option. This will rebootthe phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization"or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK mentioned earlier getsswitched back on)
10. Completed. You have now unlocked your phone.
tested on e900 and d900 phones - may work on similar models but not sure
ps this will work with your new sim but if you try anither sim not used in thatphone bofore it will need code doing again
Apr 03, 2011 | Cycling
Don't have a code for my sond remote control to
if it is an old remote it may not be compatible with your television though this is hardly your television manufacturer's fault since its not claiming to be universal : 3
Without knowing the model of your television i can certainly not help further as your remote control website found at:
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMTV501C
does not list samsung as an option. THERE IS however, an option to request a code from sony at the top right of the page so I suggest you try this option for speediest response. Please mark this solution as helpful <3
Oct 29, 2009 | Samsung Televison & Video
Need unlocking code for samsung c300
hi,
THIS CODE WILL UNLOCK ALL OF THE NEW MODEL SAMSUNG PHONES EXCEPT SMART PHONES. (X495-AND UP)
NEXT ENTER
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; adsByGoogleRight = "5px"; document.getElementById("ga_300x250").style.width = "370px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //--> var niB = document.getElementById("niBannerID"); if(niB && niB.style.display=="block"){ document.getElementById("q_answer").style.marginTop = (niB.offsetHeight+30)+"px"; } -->
Apr 12, 2009 | Samsung SGH-C300 Cellular Phone
How do I turn ON Closed Captioning.
It sounds like that option is not available on that model , contact samsung
Dec 07, 2008 | Samsung DLP HL-P5663W 56" TV
Heating & Cooling Logo
Top Samsung Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
