Question about Amana Washing Machines
How do I open my Amana top load washer when the door is lock and nothing is in it
Went to try and open my top load washer door to add a load first thing I notice was the lid lock blinking then tried too open it but it would not open
Posted by sharnece mack on
Chris Huff
    Top Expert:
  • Amana Master
  • 6,289 Answers
Unplug it for 10 minutes
Posted on Jan 07, 2019
5 Related Answers
Richard Lew
  • 489 Answers
SOURCE: Fron t Load washer will not unlock
Usually, the door will not unlock because there is water still inside the unit.  You will need to get the water out of the tub to get the door to open.  On the bottom left corner, there is a small door.  Inside the door is a small rubber drain hose.  This will empty out the water inside.  After awhile, the machine will unlock the door.
Posted on Jul 23, 2008
Anonymous
  • 572 Answers
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Posted on Feb 06, 2010
Anonymous
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Posted on Nov 18, 2010
tbirdfan1
Michael Thomas
  • 3051 Answers
SOURCE: amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked. The nd error code indicates "no drain". If the unit can't drain it won't spin. You're going to have to slide the washer out far enough to remove the rear panel; be careful not to damage the floor. Once you get the rear panel off you will see the pump. Be sure to have plenty of towels & a small container to catch water. I am sending you instructions from the service manual to remove and replace the pump. Another possibility is the drain line is blocked or something is stuck in the tub to pump hose.
Posted on Nov 05, 2011
richroth
Richard Roth
  • 9472 Answers
SOURCE: amana washer stuck on sensing
What is the model number of the unit?
Posted on Nov 25, 2012
Lost power to washing machine
When you opened the lid to add clothes, your Maytag sensed a door lock fault and went into protective shutdown.
Jan 04, 2018 | Maytag Atlantis MAV6000 Top Load Washer
The control locked light is on and can't start the machine
Power shd be on, try to hold down 'end of cycle' button for 3 seconds, try door after a minute or after hearing a click. IF NOT:
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.
Apr 06, 2009 | Kenmore Elite 45986 Front Load Washer
Amana front load washer door locked with door open
Feb 25, 2009 | Amana Washing Machines
Fault code on an Amana Washer
The door is open. Be sure that the door is completely closed.
Jan 21, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore front load he washer
try to unplug the unit and open the door manually by pulling a plastic ring attached to the door lock.
you can access the ring if you open the top cover of the unit and feel the ring where the door lock is and pull it down.
if you were able to open the door, you can check the clothes and remove the one that was jammed on the door. then test the unit for normal operation.
tnx 4 using fixya,
drcool
Oct 19, 2008 | Kenmore Elite 45986 Front Load Washer
Top loading washer door locked
check the panel for triped breakers - check the plug for the washer - the door latch usually release itself after fewhe latch minutes- if nothing works try to force lid open with a thin screwdriver from the side were the door latch is
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
556 people viewed this question
Top Amana Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
