Question about Whirlpool Washing Machines
I have a tcl tv I can't get it to work i replaced all the boards
Posted by Kenneth Jackson on
Why won't my 65s4 TCL tv backlights get power?
You have built a new television! This explains the issues you are facing and why it is happening.
https://www.fixya.com/support/r29790007-repairing_own_television
I have tcl led m. no 24d20 only displays tcl logo and then no responce
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again. Also try bringing up the menu, and see if there's an option "factory default", and try that.
2answers
TCL model L40S4690E. Why does TCL logo appear on screen and nothing else happens?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
2answers
I have a 40" TCL TV with one black vertical line on the screen.
Your set has some board that performs the function to connect the screen to the video-generation function of the TV. Either your LED/LCD screen is failing or the video function is failing. If the set is under warranty, contact the manufacturer using the information on the warranty statement. Try using a different video input (hdmi/composite/etc) for the TV and see if you get the same line on all inputs. If there is no separate board, the next step would be to try and replace the main video board. With the prices falling on lower resolution TV's, it would probably be cheaper to replace the TV than trying a repair, if it is out of warranty. 40" 1080p TV's can be had for less than $200 at some sales (e.g. Black Friday).
Tcl tv screen
T'Con board is faulty. Should be replaced.
Apr 30, 2013 • TCL L32D20
2answers
TCL 21K77 Problem with TV/AV without Remote Control
You may have to find a direct replacement for the remote, no real solution.... Let me know the brand....
25helpful
5answers
Help for TCL Brand of tv
I WANT THE SERVICE MODE CODE FOR MODEL NO: DP21E101 TCL TV 21"
Washing Machines Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
