Question about Maytag Refrigerators
Pull fridge out and make sure everything isn’t covered in dust.
Posted on Jan 07, 2019
Check that fan in freezer and at compressor is running. Also check for frost buildup on inside back freezer wall which would indicate a defrost problem
Posted on Jan 06, 2019
Testimonial: "Check for the response. The freezer temperature is ok. Do I still have to check the freezer fan? There is no frost buildup as I fully defrost and clean it dry."
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Posted on Nov 18, 2008
SOURCE: Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Posted on Jan 12, 2009
SOURCE: Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Posted on Apr 19, 2009
SOURCE: Creda R335NW Fridge/Freezer. The fridge section
The fridge gets its cold air from the freezer through a vent
between the freezer and fridge.The fan in the freezer blows air through
it. There is a flap you adjust with the
fridge temp. control. Make sure it's opening and closing when you adjust the
fridge temp
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
Posted on Jul 03, 2009
SOURCE: maytag mff2557hew fridge not cooling. Freezer ok.
Sounds like the Freezer Fan is wearing out or is worn out. This fan problem is very hard to detect. The reason is that when the motor is starting to wear out the fan will spin, but at a much lower rpm. This is enough to keep the freezer cold. but will not ciculate enough air thru the freezer and the refrigerator to prevent freezer from and refrigerator from cooler. The cost to repair/replace this fan is a minimum of $300.00
Posted on Jul 28, 2009
Testimonial: "Your solution was right on the mark! The fan was spinning but not fast enough (according to my repair guy). Thanks again!"
Feb 01, 2018 | Maytag Refrigerators
Jul 26, 2011 | Maytag Microwave Ovens
Jun 28, 2011 | Maytag Refrigerators
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 05, 2011 | Maytag Top Mount Refrigerator w/Cool Flow...
Oct 21, 2010 | Maytag Refrigerators
May 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
Apr 27, 2010 | Maytag (MFI2568AEW) Bottom Freezer French...
Jul 27, 2009 | Maytag MBB2256G Bottom Freezer...
Nov 18, 2008 | Maytag Refrigerators
Jun 22, 2008 | Maytag MBF2254H Bottom Freezer...
142 people viewed this question
