SOURCE: cd won't play
Easy fix, look at the front of your CD player, you should see a little pin hole, insert a paper clip into it and the pop the CD tray open.
SOURCE: CD Player in Acura TL 3.2 2003
It's not that hard to fix it yourself.
for your 2003 TL
1. first remove the CD player (this is the hard part).
2. with the CD player removed, unscrew the top cover (4 or 5 screws) on the CD player.
3. with the top cover removed you can see the stuck CD.
4. all you have to do now is just push the CD out and reinstall
should be the same for your 04 TL but im not sure
SOURCE: The CD player on my Sony Dream Machine FM/AM CD
The laser has gone weak. If you feel confident taking it apart, unplug it and look for a small potentiometer on the CD reading pickup. Turn it to the right to about 700 ohms, it should start reading again. If you don't have a multimeter to measure it then get one, a basic $10 meter will do fine.
SOURCE: 2008 Nissan Altima radio (AM/FM/CD) does not
2008 Altima radio-the sound just quit working. Everything else seems to be OK. I can change the radio stations, but no sound. Is there a fuse that could be bad?
