Question about Radio Communications
Regarding Opel / Vauxhall Vivaro radio code, when I go through the sequence nothing happens when I hold Down the AS button no beep any ideas
Posted by Paul mccabe on
5 Related Answers
Tom Palmer
  • 3 Answers
SOURCE: vauxhall vivaro wont start cold
Sounds like a faulty cold start assistor. On top of the engine you will find an aluminium housing with four things that look like glow plugs screwed into it. These 'glow plugs' are only available complete with the housing fron Vauxhall. Approx £70 +
Airbag light is probably a fault with the seatbelt pretensioner.
Check the wiring under the seats for damage or perhaps the plugs have pulled apart.
Posted on Jan 28, 2009
Anonymous
SOURCE: I have a vauxhall vivaro
Hiya,
I did this last week for a Vivaro that I have just bought.
This will defo get it out of safe mode and will get it working again If you have the code... Switch engine on with stereo off. Hold down AS button then turn the stereo on...safe mode should dissapear then press number one until the right digit is in the box and continue until the 4 digits are in. Then hold AS down then turn the stereo off again.
If you don't have the code contact the dealer for it usually £25 or buy the code online if you get the code number from the back of the stereo. Look for Grundig stereo codes or something like that online, there are loads on ebay.
Anyway
Good luck
Louise
Posted on Aug 09, 2009
Anonymous
  • 120 Answers
SOURCE: 1998 Chevy Lumina radio
Unlocking the system from the manual.
1. Turn on ignition. LOC will appear.
2. Press MN and '000' will appear.
3. Press MN again and hold until you see the last 2 digits of your code.
4. Press and hold HR until you see the first 1 or 2 digits of your code.
5. Press AM FM after you make sure the code is correct. SEC should appear, meaning your system is ready and still secure. If LOC appears, the code was wrong. Good luck
Posted on Mar 22, 2010
xxxxxx xxx
  • 5013 Answers
SOURCE: need code for my cd player in my vauxhall
Unfortunately the majority of SIEMENS/VDO codes
(including your CDR2005) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
Posted on Mar 30, 2010
xxxxxx xxx
  • 5013 Answers
SOURCE: Radio code Vauxhall Philips CCR600 post year 2000
Unfortunately this CCR600 code will only be available from your Main Vauxhall dealer or by using a Radio decoding Service
It will not be available for free from anywhere on the Internet
Sorry
{;o(
Posted on May 16, 2010
My opel vivaro van on 7 safe and I pressing the as button and on and wont give me the ----
You must leave the radio ON like this until the SAFE mode clears.
When it does, to get the code accepted, press AS and then a couple of seconds later the 'on' button, together until it beeps.
As you know you will then see 4 dashes. Each dash is a number from your code.
Use the numbers along the radio (1 is first number in code, 2,3 and 4 the other numbers and so on)
As an example, if your code was 4432
press button '1' 4 times (gives a 4)
button '2' 4 times (gives a 4)
button '3' 3 times (gives a 3)
button '4' 2 times (gives a 2).
When you see your code displayed correctly on the screen press AS until you hear a beep.
HELP Radio SAFE mode
May 14, 2016 | Opel Cars & Trucks
After serviceing injector pump for opel vivaro CDTI 1.9 2003
NO START OPEL VIVARO FIX - YouTube
? 3:39
www.youtube.com/watch?v=i_G7Al9IFuU
Jan 21, 2014 - Uploaded by anto denn
All it does is crank but as soon as you fiddle with the injector ...Help have a 2003 trafic drove fine then one day i drove 100 yards and it just ... is the fuel pump turning on when you turn the key ?... Vauxhall Vivaro 2 0 CDTI Turbotune tuning box fitting guide - Duration: 6:40. by Darren Darling 28,094 views.
Sep 28, 2015 | Opel Cars & Trucks
Vauxhall meriva wont start after changing flat battery.the message safe is showing on dash board
Make sure ignition is switched on, hold down button AS and turn on the stereo. Wait for the beep, then release button AS. Display should now have 4 dashes ----. Enter correct code using the radio preset buttons 1 to 4. Once code is entered, press and hold down button AS again until code is either confirmed or denied. WARNING - you only have a max of 10 attempts to get it right, but if still no luck after the 8th attempt, STOP and contact a Vaux dealer.
or you could buy something from these folks:
http://www.m-99.co.uk/Car_Radio_Decode/car_radio_decode.html
Car radio code calculator Decode Serial Digital mileage adjustment...
Feb 06, 2015 | Vauxhall Cars & Trucks
Car stereo not working,, could be in safe mode ?
Sorry to tell you this needs to have the code reset once you remove the battery the stereo needs to be reset only a garage can do that there is no doubt about it. Hope this helps Best wishes, Malcolm Campbell.
May 09, 2017 | Vauxhall Cars & Trucks
Vauxhall corsa says SAFE how do i unlock please
Here is how you unlock it:
1) Turn radio off
2) Start engine
3) Press and hold down AS button
4) Turn On radio WHILE holding down the AS button until there is a beep
5) Dial the code using the 1, 2, 3, 4 keys (eg: 1234 would be 1 once, 2 twice, 3 three times and 4 four times)
6) Press and hold AS button for approx 5 seconds
Mar 02, 2011 | Car Audio & Video
Where's my fuel filter located in my vauxhall vivaro
opel vivaro ,its a belly tank and its mounted amidships ,about time they dropped the vauxhall and the holden names ,havent got a 1960s rust bucket cresta laying around in the garage have you ?? or a MkIV zodiac executive ,swop for a 1956 morris oxford ???
Feb 15, 2011 | Volkswagen Tiguan Cars & Trucks
I have a vauxhall vivaro and I have the code however i cant get it out of safe mode - i have tried holding down AS button for 3 seconds and switching the stereo off and then on etc and nothing has worked?...
Hiya,
Anyway
Good luck
Louise
May 29, 2009 | Car Audio & Video
How do i enter the radio code on an opel vivaro van
Hi just this second fixed mine. Turn on ignition then turn radio off press and hold the AS button and keep it depressed while turning radio on. The display will now show a number for how many attempts you have and 4 dashes. press button number 1 till the first digit of youe code is displayed ,then button number 2 again till the second digit of your code is displayed and repeat with number 3 and number 4. when the correct code is displayed push and hold the AS button and keep depressed while turning radio on (basically a reverse of what you did to access input code screen.you will hear a beep, the screen will recall its memory takes abbout 20 seconds then your good to go... Hope this helps.
Jan 30, 2009 | Car Audio & Video
Radio Communications Logo
146 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
