Exercise & Fitness Logo
Spirit Fitness Treadmill XT285, literally does a hard stop after 30-40 minutes, no warning, no error message. Motor was hot, repair guy replaced motor, now it does a hard stop within minutes???? What is wrong? Mother board? Treadmill is only three years old. He said belt was fine and treadmill was in great shape. So fruatrated!!!!!
5 Related Answers
frannyjunk
  • Posted on Nov 17, 2008
SOURCE: tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
vpaaf
Howard
  • 115 Answers
  • Posted on May 01, 2009
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
gdcroft
  • 192 Answers
  • Posted on May 15, 2009
SOURCE: Your Problem: Spirit Treadmill motor will not turn on
I'd start by attaching a voltmeter across the motor contacts to see if you get any voltage when the unit is turned on. It's probably an AC motor but I'd check the label to be sure. If you get voltage but no turning either the motor or a startup capacitor is bad. If this is the case try moving the tread by hand with the unit turned on. If it moves on it's own after you start it moving then the start up cap needs to be replaced. Otherwise it may be time to replace the motor. If you don't have voltage across the motor contacts when the machine is turned on, I'd unplug the unit and trace the lines back from the motor to somewhere on the PC board. I'm guessing there's probably a relay on the PC board that controls the motor. I'd use an ohm meter to make sure the relay coil hasn't turned into an open circuit. Next I'd put a voltmeter across the relay coil, plug the unit back in, and turn the treadmill on and off several times. Ideally you should see the voltage across the relay coil go up and down as you turn the treadmill on and off. This voltage could be AC or DC depending on the type of relay used. If you get the proper voltage across the coil but the relay contacts aren’t' opening and closing to provide power to the motor then you need to replace the relay. If you don't get the proper voltage across the relay coil the problem is further back on the PC board.
Anonymous
  • 16 Answers
  • Posted on Feb 20, 2010
SOURCE: Life Fitness Treadmill "FET" error
Can you please provide model of unit.
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on Mar 01, 2010
SOURCE: Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
My treadmill LIFE FITNESS T3 blocked and the console display the following message : ERR 6 / ERR KEY BLOCKED. Turn ON /OFF. Does not fix the problem. What does it mean and how to proceed? Thank you.
How do I fix error 6 on my treadmill?
E6 Error: Controller malfunction. Resolution: Ensure that the cables connecting the console and the controller are secure. If any of the cables/connectors appear loose, completely power off and unplug the treadmill before unplugging and reattaching the cables.Sep 23, 2021
E6 Error Code: Control Board Malfunction - Spirit Fitness Support
https://www.google.com/search?q=LIFE+FITNESS+T3+ERROR
Spirit treadmill st200
That machine is way too old to put any money into it. The fix for that particular problem is to replace the deck and belt.
I have a Spirit XT285 treadmill and it says it is at a zero percent incline but it is definitely not flat. I ran the calibration and it is still not level. I used a level to check and the bubble is not...
I have the same machine, and I have a feeling that it has a natural 1% incline which is supposed to simulate the difference with no wind resistance.
2helpful
2answers
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Top Spirit Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
