Question about Mitsubishi Televison & Video
Does any mitsubishi remote work with any model
Posted by LAWRENCE Subick on
I would like to program my Mitsubishi
Mitsubishi Key Programming Instructions
  • Hold both the lock and unlock button until the lights flash three times.
  • Let the buttons go.
  • Push the unlock button until the light flashes two times. Your car is synchronized.
  • Test the connection to make sure everything is working properly.
How to Program a Mitsubishi Key Fob and Change Its Battery
How to Program a Mitsubishi Remote Control ' Techwalla
https://www.techwalla.com > ... > Entertainment
Your Mitsubishi TV's remote control can be programmed to control other devices. You can program the remote to operate your VCR, cable or satellite source, ...
The problems of not showing
make model (what it is)
3answers
Mitsubishi model#VS4552A/ need to know how to access and change settings without remote
can't be done but almost any Mitsubishi remote made over the time of 10 years or so of this set will work.
2helpful
2answers
Hi can you help me please , ive bought a polaroid lcd tv model no p40lcd12 . ive looked everywhere on the net for the remote code for my sky + remote. sky dont have it listed .has anyone got it .would...
I bought the same TV yesterday and I've used code 1065 to program my sky remote, which worked fine. It's thanks to the answer relating to Mitsubishi and TiVo cos I used a Mitsubishi code!! Hope it works for you.
2answers
Mitsubishi WD-60735 Control issues
This set has aside from the recessed front reset two more done with the Mitsubishi remote.
The soft reset "should" be with set on Menu, 1,2,3, enter
The hard reset requires a 4 digit number code and is based on model number and also done with the Mitsubishi remote--try to see if soft reset works at all on this model.
I have a Mitsubishi HS-U446 vcr and it works fine but the remote is totally worn out--is it possible to get a new one? Where?
There are several companies out there that make replacement remotes, and do not charge a fortune for them I used to have a similar model and got a replacement remote for about 40.00. It may seem like alot, but for that model and the Mitsubishi VCR's in general, I think of it as a wise investment. I used a Co. called Replacement Remotes.com. Ther also is another one called Smart Home remotes.
Replacement Remote
Hi
Thanks for using FixYa. Yes Universal remote control can be used on Mitsubishi TV CS32307 for which you can place order on the following link---
Replacement Remote Control for Mitsubishi TV CS32307
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
How do i get c/captions , i do NOT have a factory remote model # cs-26201
Oddly the Closed Caption function in that set is accessed with the remote by pushing the VIDEO button which cycles through contrast, brightness, tint, color and eventually to CC. You don't need the factory remote just one of those generics specific to operating a Mitsubishi tv. Just google Mitsubishi remote and you'll find some relatively cheap that work fine.
6answers
My Polaroid TV model not listed, it's TLX-04240B
Can the remote do a code search? I had to do that with my Tivo remote to control my new Polaroid.
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
