Question about Woods Hardware & Accessories
TB Woods Etrac AC Inverter, can it be programmed to auto start after a power loss?
Posted by Timothy Sells on
Overmod
    Habit-Forming:
    New Friend:
  • 20 Answers
Probably more help if you provided the full model number.
The programming manual says you can set this in code 82 START. Probably data code 1 is what you want, but look at some of the other codes provided and the parameters that affect them.
If you need additional information, call TB WOODS at their handy number: 888-829-6637.
Posted on Apr 10, 2019
What causes a red light on an TB Wood Etrac XFC 1001 inverter and the motor will not start Is there an internal fuse Do I need 3 phase for the input
Is that red light flashing or continous lighting? You do not need 3 phase input for that model. Do you have the input wiring diagram? If the red light is flashing maybe the emergency stop input is active. If the red light is on continously then it maybe in stop mode or torque limit, ask electrician to check the wiring.
Dec 31, 2016 | Inverter Electronics - Others
I have an F16 fault on a TB Woods Etrac drive. Can u plz suggest me what should do.
If it is readable copy the data off immediately, if not you need to take it to a data recovery service such as ERS Data Recovery at 1.888.248.3148 What yo depends on how important the data is.
Dec 08, 2016 | Computers & Internet
I have a woods model 50007/50027 indoor 24 hour digital timer. I can not set it to automatically go on and off... it either says... auto on or auto off and does not indicate auto by itself. the timer...
Click to Auto Off. The system defaults to Auto Off when you complete the programming. The instructions do not cover the two 'auto' settings and it is confusing if you hit the power setting without knowing.
Aug 17, 2013 | Woods Hardware & Accessories
I have a auto pro 800 watt inverter that gives 220volt ac **** wont run my kellerman freezer it runs in the house on ac can you help
If your freezer need more than 800 watts to run then your 800 watt inverter will be overloaded and it will shutdown.
Mar 21, 2012 | Vector 1000w Power Inverter
How do I set in Automatic mode, seems to only work manually since loss of power?
1) Power outage is major cause of timer failure. Power surge occurs when power is restored, and electronics are susceptible to surge. This includes water softerer, treadmill, electronic water heater, timers, etc.
Timers should be unplugged when power goes off.
Of all timers on market today, only one instruction manual says to unplug timer with power loss. However many people write fixya saying their timer, and electronic water heater control etc stopped functioning after power loss. Probably other products have same problem, but I work with timers and water heaters and see only that slice of the world.
2) Question posted under Woods 59377.
Several timers look identical or similar.
59377 timer has non-replaceable rechargeable battery, some similar timers have AA battery.
If timer has battery, change battery.
Then reset timer to restore functionality. Press reset button for a few seconds with paper clip.
3) If timer function does not restore after reset, then timer is bad.
Buy similar timer at Lowes or Target, and return defective timer in new package.
4) If function is restored, then re-program timer
Open following link for timer instructions showing how to reset timer and re-program timer:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Sep 09, 2011 | Woods Industries 59377 Indoor Digital...
How do I program Woods digital timer 59203?
Link shows all Woods timers and manuals
http://waterheatertimer.org/Woods-timers-and-manuals.html
If instructions below do not match your timer, look through timers on Woods page to identify, and then add a comment.
Manual for 59203
http://waterheatertimer.org/pdf/Woods-59203.pdf
Instructions below are for Woods 59203 & GE 59203 plug-in programmable timer with 2-prong polarized outlet:
Plug timer in until battery is charged.
If display will not show, then timer battery needs to be recharged, or timer may be busted, or electric circuit is tripped off, or electric circuit heeds to be tested with circuit analyzer.
Set current time:
Press and hold CLOCK button.
Press HOUR and MINUTE to set correct time with am and pm.
Press Day button to set current day.
Release clock button.
Program timer:
Press PROGRAM button until "1 ON" displays. This is program1 ON.
Press MINUTE and HOUR buttons to set ON time for program1
Press DAY button to choose day or group of days for program1 ON
Press PROGRAM button until "1 OFF" displays. This is program1 OFF
Press MINUTE and HOUR buttons to set OFF time for program1
Press DAY button to choose day or group of days for program1 OFF
Press PROGRAM button until "2 ON" displays. This is program2 ON.
Repeat steps above to set ON and OFF time for 5 programs.
When programming is completed, press CLOCK button to exit programming.
Press ON/AUTO/OFF button until Auto displays.
Make sure lamp is turned on.
Make sure bulb is good.
Dec 11, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
HOW DO i SET THE WOODS 59203 TIMER LOST DIRECTIONS
Woods timers and manuals:
The picture shown at fixya for 59203 is not correct.
Picture shows 49112 which is also TD1000:
Manual for 49112-TD1000:
http://waterheatertimer.org/pdf/Noma-TD1000.pdf
Manual for 59203:
Manual shows 15 steps.
Plug timer in to charge battery. If battery will not charge, then timer is bad.
Set current time.
Set program1 ON time.
Set program1 OFF time
Set program2 ON time
Set program2 OFF time up to 20 pairs of ON-OFF times.
When programming is complete, press ON/OFF/Auto until Auto shows in display.
Add a comment of you need help with specific programming.
Nov 28, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
I caNT SEEM TO PROGRAM OR CHANGE THE TIME . HOW DO I DO IT
Page showing Woods timers and models:
Add a comment with specific model number and I will help.
Instructions below are for Woods 59203 24-hour digital timer:
Plug timer in until battery is recharged.
If display will not show, then timer battery is dead and needs to be recharged, or timer may be broken.
Set current time:
Program timer:
Nov 27, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Can I connect vacum cleaner big one with Black & Decker 100 Watt power inveter
No,
You will need a much larger power inverter than that to run that vac...
heatman101
Apr 22, 2010 | Black & Decker 100 Watt Plug-In Power To...
Hardware & Accessories Logo
217 people viewed this question
Top Woods Hardware & Accessories Experts
jdthefixer
NOEL
NOEL
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
