Question about Camping, Backpacking & Hiking
What is the replacement bulb for a FP lantern model #72384
Posted by William Cooke on
Don A
  • 2,617 Answers
I believe you are referring to a Finbury Park lantern. The following site sells FP lanterns and bulbs. I suggest you query them with the specifics.
https://www.lights4living.com/elstead-finsbury-park-lights/s463
I hesitate to suggest other "bulb" sites as they might lack the ability to find the bulb simply by the lantern ID. If the bulb has an ID number, that would help.
Here is one such "bulb" site:
https://www.1000bulbs.com/?msclkid=85883f8c924112a60229634ff913f1ec&utm_source=bing&utm_medium=cpc&utm_campaign=Light%20Bulbs&utm_term=cf18dde841%20bulbs&utm_content=1%20Metal%20Halide
Posted on Apr 26, 2019
1 Related Answer
Boneebone
  • 973 Answers
SOURCE: trying to find replacement bulbs for our Swissgear
You can find the bulbs you need at this link; http://www.bulbs.com/eSpec.aspx?ID=14393&Ref=Light+Bulbs%2c+Ballasts%2c+Fixtures+and+More&RefId=0
Posted on Jun 25, 2010
How do I change the bulb of the 6V Eveready Lantern if bulb won't come out
Drop a couple of drops of WD 40 on the bulb retaining ring. Let site overnight and in the morning it will easily unscrew. Note: be sure you use only a couple of drops as you don't want to get it on the reflective lense
Sep 27, 2014 | Energizer Eveready Utility Lantern Uses 6V...
How to test a flashlight bulb
To test a flashlight bulb you use an Ohm meter which will detect a broken filament or an open circuit within the bulb. If the bulb is bad it will read "OL" if it's good it will read "00.0"
Jun 14, 2014 | Energizer Eveready Utility Lantern Uses 6V...
Rayovac 360 sportsman lantern wont work
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
Nov 01, 2012 | Camping, Backpacking & Hiking
How do I change the bulb of the 6V Eveready Lantern?
If it is the yellow floating lantern you have to remove the black plastic stub on the underside of the reflector using needlenose pliers to wiggle and slightly pull until it releases and the bulb will come out.
Jan 06, 2011 | Energizer Eveready Utility Lantern Uses 6V...
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
Coleman rechargeable lantern: Charged overnight - not working, replaced bulbs - not working. What could it be:
Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
Jul 20, 2010 | Coleman Camping, Backpacking & Hiking
I have a GE Hurricane lantern model # 17000, how do I get it apart to put new batteries in it? There is an arrow on the bottom of it pointing to oppen one way and close the other, but nothing is budging.
I have the same latern. Apply a bit more force to rotate the bottom lid in a counter-clockwise direction. There are threads on the inside of the botton lid. To replace the battery or bulb you go through the botton of the lattern.
Jun 30, 2009 | Camping, Backpacking & Hiking
Camping, Backpacking & Hiking Logo
238 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
Kardoc
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
