Question about Craftsman Garden
I have a Craftsman 9.5 model 944.525392 Snowblower. Power to one of the drive wheels has stopped. I opened the transmission. The friction ring is worn but still able to move the friction plate so I ruled that out as the problem..I the took the axle assembly apart on the side that is not engaging and this small square pin fell down.. I’m thinking this is the problem.. can somebody identify this pin and if it could actually be the problem?
Posted by Jeff Paul on
Jeff McCrea
    Novelist:
  • 144 Answers
That would be a half round woodruf key. If the piece that fell out is long and rectangular in shape, this is the piece that has broken off from it. You'll have to drive the remaining piece out of the shaft key way, take it to a repair shop and buy a new one that is exactly the same size. If it is too big, it won't fit. If it is too small, it will slop around and break again. If it is stuck, take a pointed punch and hammer and drive one end or the other DOWN, NOT THE MIDDLE, and it should slide out like a chair rocker. When you go to install the new one, you have to put the round end into the key way, align the grove in the wheel hub with the key and CAREFULLY slide it on. If you bump the key and dislodge it, the wheel won't go on. Just pull it back off and relocate the key in it's groove. Good luck.
Posted on Jan 04, 2019
5 Related Answers
SOURCE: toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Posted on Mar 18, 2009
SOURCE: drive chain loose and poped offmy snowblower
Two things you can do. First if you look close you may see a spot where you can adjust the chain tension. Nest your chain should have what is called master link. Look close and you will see a clip that undoes the link. Pull the link out and the chain will come apart. If you are not mechanically inclined take it to any small engine shop and they will take a link out for you and then you will be home free.Hope this helps. donnyb60
Posted on Mar 23, 2009
rwvanlue
Roland W VanLue
  • 486 Answers
SOURCE: looking for governor linkage set up took apart
cc4d3bd.jpg hmsk linkages
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 22, 2009
Testimonial: "Just what I needed. Thanks"
Anonymous
  • 64 Answers
SOURCE: Four wheel drive wont engage. Tranfer case is
Sounds like you either have a vaccum leak or your 4 wheel drive actuator is not working to engage the front differential.On my 98 ram there is a black and red plastic lines that are used for the vaccum lines. They are underneath and go from the transfer case to the front axle, check to see if one or both might be cracked or broke completely.If the lines are good then it could be your actuator on the front axle. A new one is about $93 at advance auto parts and not very hard to replace
Posted on Dec 15, 2009
wcbotha
Willem Botha
  • 92 Answers
SOURCE: 2001 kia sportage 4x4 trouble
Check front wheels there is 2 pipes going to the wheels 1 is for brake fluid to the callepers and the other one is for vacume suction to ingage or dis ingage the free wheel function 99% of the time this pipe is leaking or it is broken. enjoy !! Willem SA
Posted on Feb 23, 2010
Noma snowblower transmission is backwards, put in forward it goes backwards and so on
Dear Richard,
Your direction with the gears appears to be 180 degrees out. You may also consider flipping the entire shaft assembly. You. Knowing this assembly is put together correctly.
At this you tube link you will find information to watch for your Norma. The side bar with a catolgue has your answers.
Here is a forum and a blog that may help when the order is corrected
Small Engines Lawn Mowers etc Noma Murray Snowblower question
Craftsman Murray Snow Blower Belt and Friction Wheel Replacement
Dec 09, 2014 | Garden
I have a 8/26 mastercraft snowblower Model No.
Have you checked all belts and belt tensioners? If so, you will have to tip unit up and take bottom plate off of unit. The drive system consists of a rubber lined wheel that makes contact with a friction plate once handle is depressed for drive. As you change gears you can see rubber drive wheel changes position in relation to friction disc to change speed. If belts are good, I would look in this area for problem. These rubber lined dive wheels do wear out and are replaceable. Also, on some models you can adjust further. Hope this helped. Happy wrenching!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 09, 2013 | Garden
I have a MTD 5/20 snowblower that won't engage in Forward. It will transfer to neutral and reverse, but I can't any forward power. If I tilt it forward, the wheels will spin. I installed a new belt and...
ALL SNOW BLOWERS HAVE WHAT THEY CALL A FRICTION DISC DRIVE IT SOUNDS LIKE THE FORWARD SIDE OF THE DISC IS WORN OR THEDRIVE WHEEL HAS A RUBBER DRIVE RING THAT IS WORN. IF YOU REMOVE THE BOTTOM PLATE YOU WILL SEE TWO DRIVE WHEELS ONE IS JUST A METAL DISC AND THE OTHER LOOKS THE SAME BUT HAS A REBBER RING FOR GRIPPING THE DISC TO MOVE THE BLOWER FOREWARD, WE END UP REPLACING ALL THE DRIVE DISC AND DRIVE WHEELS ON OURS EVERY SPRING THE FOREWARD DRIVE TAKES THE MOST PUNISHMENTTHERE FOR WHEARS OUT THE FASTEST. MTD HAS A WEB SITE FOR ORDERING PARTS AND ARE NOT HARD TO INSTALL.GOOD LUCK LET ME KNOW HOW IT GOES
Feb 05, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
I have a 2 yr old 8HP Craftsman snowblower. My small engine buddy picked it up in Nov to give it a tune up check the belts etc..I had been doing yearly maint on it but wanted to see how he busted it apart...
Are you trying to move the gear selector with the engine off? This is a friction wheel/disk transmission and the friction wheel usually will not move on the drive disk without the engine running.
If you have the bottom cover off, lift up on the drive wheel. (The rubber wheel. Lift it off the drive plate) It has tension on the plate using a spring. The gear shift lever should move then.
If it won't move check the sliding mechanism for the friction wheel and make sure it has a little grease on the shaft it slides on. Also check the cable and the pulleys the cable runs in. Sometimes the engagement cable (forward drive lever on the handle) falls off the pulleys. Sometimes these little pulleys will break.
These Craftsman snowblower transmissions are all basically the same. Here is a manual that shows the drive system.
http://www.managemylife.com/mmh/owner_manuals/23825/CRAFTSMAN-Snowthrower-Gas-L0909129?brand_name_search=craftsman+88970 Look at page 20, figure 22.
Let me know if you have any other questions or you need more clarification.
Jan 10, 2011 | Craftsman Garden
Ariens SnowBlower I recently blew a belt on my Ariens 5.5 hp snowblower Mdl# 932140 I replaced it and it blows snow and when i put it in 1st gear the machine goes into reverse. All my other gears work...
Hi dwva, I think you have the belt on properly seeing the other gears work fine. The difference between 1st and reverse can be as little as 1 half in on the drive wheel. It depends on which side of center is the friction wheel riding. Remove bottom pan with the machine in 2nd or 3rd gear notice which side of center is the friction wheel riding. (the friction wheel is the one with a rubber outer ring). Now put it in 1st, is it on the same side of center? There is an adjustment on that linkage, adjust so in 1st is on the same side of center. Happy New Year, hope that helps.
Dec 29, 2010 | Garden
CRAFTSMAN SNOW THROWER DRIVE WHEELS WILL NOT MOVE - RAISE REAR UP AND WHEELS DO - AUGER WORKS IT JUST WON'T MOVE
well if it is a walk behind style it could be the drive is out of adjustment, also craftsman were famous for the cable mounts bending and that will throw them out of adjustment. follow the traction drive linkage down to the base of the blowe and there should be an adjustment, or it will be under the belt gaurd or even on the handle on some.
Feb 02, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Apr 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Ariens Snowblower won't engage into drive
I had the same problem with my 5HP Dual stage (C950-520240) Canadian model and found that the arm connected to the traction cable (part #85449 "Shaft Traction Clutch") which forces the friction disk up to the rubber friction wheel had a cracked weld and had bent, preventing positive contact with the rubber friction wheel. The drive wheels would turn if you lifted the back of the machine off the ground, but would not work if under load. First I replaced the belt and rubber friction wheel, but no go. I had to basically disassemble the whole drive assembly to find the problem, very frustrating because you could not see the crack in the arm from head on. I had the cracked and bent arm straightened and welded, all is OK now. enb54.jpg
Dec 05, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
62 people viewed this question
Top Craftsman Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
