SOURCE: Sebo X14 -red light comes
Unless the circuit board is bad, you still have a clog, Either in the hose, or the dirt inlet by the brush roll.
SOURCE: sebo automatic x4extra 1300w
Check for any blockage in the hose or the inlet by the brush roll. Is the brush roll jammed? There are 2 circuit boards, one for the 12V power supply and the other is the computer controller, one of these may have gone bad.
SOURCE: sebo automatic x4 power cuts
Could have a problem with the cord or maybe the switch. The swivel neck has wires runing from where the want plugs into and plugs into the a circuit board, sometimes one of the wires opens then the motor cuts in and out. There also is the motor and a computer controller causing a problem.
SOURCE: The Clog light is on my Sebo Essential G1 vacuum
If you are sure the base is clear, and that the flexible hose and attachment tube are clear, the only other common place for a blockage is the swivel neck that joins the base to the bottom of the dust bag housing. Here's what to do:
Press the housing release button (front bottom of bag housing) and lift off the bag housing from the base. This can be quite hard (three or four hands would be helpful) but be sure to lift straight. When you've got the bag housing off, release the foot pedal and lower the swivel neck to 45 degrees. Check inside the swivel neck channel closest to the foot pedal, and clean it out as necessary.
If this doesn't work, please post again and I'll see what else I can do... If it does help, please rate me!
SOURCE: full bag clog light
1.If your sebo is less than five years old, you have a reciept, and are not using it commercially, in most cases this machine will still be under factory warranty. To locate
an authorized sebo dealer simply call sebo or use the dealer locator on their website.
2. If it is no longer under warranty:
First i would pick up something small such as a balled up gum wrapper and make sure it makes it to the bag, more often than not something is not checked, and its still plugged. Heres how i'd check for plugs.
Simply go back up through the steps to reassemble.
If your test makes it into the bag just fine and you are not plugged, the tall filter inside the bag compartment would be my next suggestion and since you changed this it should not be a problem. This leaves few possible problems. Circut board error/Sensor error would be my next step. Essentally its one in the same, but there is no great way to test them without simply replacing parts. (an expensive proposition) The local sebo dealer will more than likely have a working used board they pop in and out to check for problems. Some dealers may let you use these others will require you either buy the parts or pay for labor.
*Bad boards in sebo/windsor products are extremely rare, my bet is always on a plugged filter or plug in general. Be sure to look carefully something as small as a toothpick surrounded by carpet fuzz can set them off.
Best of Luck
