SOURCE: HP Photosmart C6100 All-In-One Printer stopped printing black ink
Please clean the print heads :
Press Setup up - Tools - Clean Print heads on the All-in-One.
If this does not resolve the issue , Reset the All-in-One.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
If issue stil persists. Contact HP.
SOURCE: INK CARTRIDGE PROBLEM Remove and check
When turning the unit on it straight away says ink cartridge problem. We are unable to proceed any further past that message. We are aware that the colour cartidge is currently empty but why cant we still scan photos on to the computer?
SOURCE: my hp photosmart 2575 says
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
SOURCE: when i switch on my printer, it tells me to check
Try to clean the place where you put the cartridges using a contacts cleaner, do the same with the cartridge.
Testimonial: "Thanks very much."
