Coleman 8631 what's the name of the box all the wires go into ? Control modular,control box,control knob....trying to find the part
After thermocouple has been replaced correctly the gas valve would be my next suggestion without physical being there. I would suggest having this diagnosed and replaced by a certified HVAC technician.
If the pilot light won't stay lit and the thermocouple is okay, then the thermostatic control valve may be defective. Replacement of this part should be performed by a trained gas technician. ... If your gas water heater doesn't stay lit, you may have a defective thermocouple.
https://www.fix.com/repair/appliance/water-heater/wont-stay-lit-keeps-shutting-off/
SOURCE: Pilot won't stay lit, replaced thermalcouple but
I would remove pilot light assembly and clean orifice and blow out gas line to pilot. Check to see that thermocouple is centered in pilot flame. It is possiblethat your gas valve is bad but it is also possible that you got a defective thermocouple. I would change the thermocouple again as they are much less expensive then the gas valves. The next time when you are sure you have the thernocouple mounted as close to the center of the pilot flame hold the pilot button down for several mins. If none of this works then you may have to change your gas valve.Thank you.
