Televison & Video Logo
Steven Aragon Posted on Jan 03, 2019
I have a Vizio 50” LED TV (model no. P502UI-B1E). Over the last couple months the TV would seem to turn off immediately when I turn it on once in a while. I would have to try 1-2 more times for the TV to turn on on occasion. A couple days ago I left TV on over night. In the morning I began watching a football game when the picture went out with audio still playing. I turned off the TV and turned it back on, but I couldn’t get video or audio. The power light indicator would go on and flash for several seconds, then turn off. There is no audio or video, even the sound bar (HDMI) does not receive any signal. I unplugged all devices and still got the same result. I already did the flashlight test to check for a bad backlight and unplugged TV and held the power button for 10 seconds. No change. Considering that there is no audio and video, the power light indicator flashes for several seconds and stops, what is the most likely cause or causes, power board, main board, T-Com board, etc.?
glass69ss118
Level 1:
Habit-Forming:
New Friend:
  • Contributor 37 Answers
  • Posted on Jan 03, 2019
glass69ss118
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
37
Questions
0
Helped
13986
Points
86
Check the capacitors first, they are usualy the weak link.
5 Related Answers
Anonymous
  • 4889 Answers
  • Posted on Nov 01, 2010
SOURCE: I have Sharp Aquos LC-65D64U
It sounds like a backlight inverter to me. I am 99% sure. The buzzing noise you mentioned kind of confirms that, so does the backlight turning off. If you want to test them, then you are gonna need a multimeter. I will see if I can find a schematic in my collection, but be aware that this is a highvoltage device we are dealing with. May not be a good idea to test it yourself if you have never worked on electronics before. The sets hold nasty voltages for several days after its turned off and unplugged, and can injure you if you are not careful. I don't mean to scare you but its my job to tell you. If you want to proceed then I'm game.
Anonymous
  • 4 Answers
  • Posted on Jan 27, 2011
SOURCE: Vizio m550nv led lcd tv. Problem began a couple
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
gopakumarg43
  • 76851 Answers
  • Posted on Mar 16, 2016
SOURCE: What could be wrong with my TV? The audio and video suddenly cut out.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
mosekha
Moses Isaosi
  • 23 Answers
  • Posted on Jul 17, 2016
SOURCE: I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. Still have sound & can see a picture with a flashlight shining on the screen.
Your Tv has Led strip that is faulty you just have to check if they are receiving dc voltage if yes then change the Led strip if no check the voltage supplying the Led
Derrick Gee
  • 3 Answers
  • Posted on Aug 31, 2016
SOURCE: Vizio E550i-b2 TV has no backlight, pic or sound. Replaced power and Main boards - still having the problem. Any suggestions? I have the TCON and LED Driver board left
The led is what makes the picture try replacing that it it's the only one you didn't change out
Vizio board part number match
Tengo una tv vizio d? 48pulgadas Modelo:D48f-EO no prende foquito de standby esta muerta
2answers
I have a Vizio p502ui-b1e that I believe was hit by lightning during a storm. The light at the bottom right comes on then flashes but there is no backlight and no picture. I'm not sure if my issues are the...
This is unfortunately a not uncommon problem that others have told me about and Vizio only advised them to buy another television.
Struck by lightning is highly unlikely.
1helpful
I replaced the Main Board, Power Supply Board, LED Driver Board, And T-Con Board on my Vizio P502UI-B1E 50" TV. It is still stuck in a Reboot Cycle. What else can I try?
After the main board replacement, in most cases, a firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
