Question about Water Water Heaters
I bought a camper, how can I check to see if my water heater is good and wired right
Posted by Paul Childers on
ray gallant
    Top Expert:
  • Water Master
  • 68,633 Answers
A VOLT OHM METER WILL TELL YOU ALL YOU NEED TO KNOW NOW . NEVER TURN THE HEATER ON BEFORE YOU KNOW IT IS FULL OF WATER OR YOU WILL BURN THE ELEMENTS OUT ., MY OLDER BROTHER LEARNED THAT THE HARD WAY AFTER DOING IT EVERY YEAR FOR ABOUT 10 YEARS
Posted on May 02, 2020
1 Related Answer
Gene Haynes
  • 5391 Answers
SOURCE: i bought this camper and it has a Atwood water heater in it and i don't no anything about it, how to light it
Copy following link:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Otherwise there are 100s of atwood water heater resources on internet covering the different models old and newer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jun 05, 2013
Gc10a-4ewater heater attachmentioned of colored wires to the back of water heater
black white and green power 120 volts other wires red yellow and blue and green 12 volt to control board
Oct 13, 2017 | Water Heaters
I have an on/off switch inside the camper and outside the camper where water heater is located. does this mean i have a propane/electric water heater?
Most likely if you have a switch that just is on/off it is for powering an electric water heater. If the water heater is propane and electric there would be a selector switch to choose between the two power sources.
Feb 15, 2015 | Water Water Heaters
Camper wiring diagram
Is there a switch or a GFCI in the circuit between the breaker and the unit?
Jul 28, 2014 | Water Heaters
I bought this camper and it has a Atwood water heater in it and i don't no anything about it, how to light it
Jun 05, 2013 | Water Heaters
BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
Dec 18, 2012 | Bradford White M240s6ds-1ncww 40 Gallon...
Atwood 7920-11 furnace will not light. I am trying to light the furnace on my 2006 Jayfeather 19H camper that is an Atwood and looks to be an automated pilot lighting system but I continually get a flame...
Your electrode acts as flame sense as well. Remove electrode and clean it thoroughly/carefully especially at end where flame would be sensed and retry. Be sure connections on high tension wire is good and clean as well as connector and contacts on circuit board as well. If still same result, replace electrode.
Oct 05, 2011 | RTO Atwood Water Heater - 6 Gal LP
We have a 2011 Keystone Sprinter 311 BHS camper that we bought last year; it has a 6 gallon gas and electric DSI auto ignition water heater, It won't stay on. When we first turn it on, you can hear...
Are you getting any hot water from taps? If not, check by-pass valve on back for proper positioning. You want cold going in bottom fitting open, as well as hot coming from top fitting open too. Any valves etc., in between should be closed. Let me know what happens please.
May 16, 2011 | Water Heaters
Water Heaters Logo
161 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
