Question about Vehicle Parts & Accessories
I need a manual for a Peak jump starter 700 - Vehicle Parts & Accessories
Posted by Rosalie Reeser on
2 Related Answers
Karl H
  • 52 Answers
SOURCE: where do I plug in the cord to start charging the jump starter (Black & amp; Sage ) 900 peak ,350
Google for an owner's manual. I can't find anything on this jump starter, but first they need to be charged, usually by plugging into a wall socket for 12-24 hours. Then plug into the cigarette lighter for 10 min or so to give the car battery a boost charge.
Posted on Dec 04, 2014
Vernon Taylor
  • 7428 Answers
SOURCE: Can you use a Motomaster eliminate Battery booster pack with Air compressor 1400 peak battery AMPS 700 crank assist AMPS To charge a battery or just jump start it
If booster is fully charged and the vehicle battery is almost discharged it is inevitable some battery charging will take place but it is likely to be a slow and incomplete process and could shorten the life of the booster which isn't built for such work.
It is also worth noting the car alternator is also not built for charging the battery and is often incapable of doing so. The purpose of the car alternator is to keep a fully charged battery fully charged and a discharged battery can even cause damage to an alternator.
Posted on Nov 25, 2017
I am looking for the large white plastic gear that moves the mechanism which produces air for the Peak Power System 700. My unit does everything but fill my tires. This gear is broken.
I could not find any part suppliers for your unit.
I sent an email to PEAK product support on your behalf.
If you need immediate assistance, please call PEAK at 1-800-323-5440 (USA), (847) 559-2000 (International).
PEAK Auto Motor Oil Antifreeze Diesel Exhaust Fluid Electronics Windshield...
FYI: I have an 20-yea- old Epson dot matrix printer that had a plastic round knob that was used to move the paper forward. I had a replacement knob machined out of aluminum. I still have the printer and the knob has never broken again. Maybe that would work for your unit if the broken gear could still be used as a template.
Mar 24, 2016 | PEAK 700 Amp Jump Starter with...
What does the flashing FL mean?
When the Jump-Starter is fully charged, the display will read FL. Disconnect the AC extension cord from the 110/120-volt AC outlet, and then disconnect it from the Jump-Starter AC charging plug. http://www.carid.com/images/peak/info/pdfs/pkc0j6-manual.pdf
Mar 29, 2015 | 600 AMP Jump Starter
I have Jump Starter JNC 660 1700 Peak AM. I want to take with me to Europe. My question is how I can charge it in the Europe
I wouldn't take it to Europe, what's the point it would cost you more to get it there than buy one there. If you do take it, you will need a 240V / 120V transformer of converter
Feb 23, 2015 | Solar JNC660 Jump-N-Carry 12 Volt Jump...
Where do I plug in the cord to start charging the jump starter (Black & amp; Sage ) 900 peak ,350
Dec 04, 2014 | Cars & Trucks
What specifications do i use to get a replacement charger for a Peak Charging Adapter . . . . . . . . 120 volt AC (700mA, 12 volt DC Output
Just as your information says ask for a 12 volt 700 ma charger..but seeing that yours is a 450 amp jumper..any 12 volt that fits your ac input will do the job...one more thing if you do not have a charger..just connect it to your battery and run the engine for 20 min or so it will recharge the car battery and you jumper..also you can get a lighter wire with two lighter plugs and charge it through you lighter..good luck
Oct 22, 2014 | 450 Amp Jump-Starter with USB and 12 Volt...
Where can I get a Manual for jump-starter 300
Battery Jump-Starter 300TM - All Power Supply
allpowersupply.com/Productlib/manual-PKC0AO.pdf
Translate this page Conserve este Manual del Propietario para referencia futura. P/N XXXXX, 3/09. 1 . TM. Battery Jump-Starter. 300TM. Model No.: PKC0AO. Owner's Manual.
Jul 24, 2014 | Peak Compact Battery Jump Starter 300 For...
How do I purchase a replacement ac adapter for peak AKC0A0 portable battery jump starter
Try the source of that non-Mopar equipment. If they don't have a website, well...........
Jun 01, 2014 | PEAK PKC0A0 300 Amp Jump-Starter And 12...
I need a 110/120 volt ac/dc adapter power cord for recharging from standard wall socket. For a Peak 450 jump starter
After searching the internet for a ph number for Peak power I finally found the web.
http://www.peakauto.com/contact/site.
phone 800-323-5400
If the part department doesn't have the answer ask to be switched to tech support.
They were able to provide me with the part numbers I need for new wall supply cord and an DC adapter for the car.
My jump starter is no longer made...
Nov 15, 2013 | Peak Performance Peak PKC0BL 450 Amp Jump...
I can't find a cable to charge the pkc0aq Peak Amp power station plus
You open the door that covers the plug on the lower side and find a extension cord and plug it in and then in to a wall outlet for about 24 hrs
Nov 23, 2012 | PEAK 700 Amp Jump Starter with...
Vehicle Parts & Accessories Logo
132 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
