Question about Amana Heating & Cooling
My displsy on my amana ptac onlu lights when you turn off master switch thr blower runs a ll the time it will not turn off
Posted by jim braskett on
David Spradling
    Top Expert:
  • Amana Master
  • 11,291 Answers
Relay or switch stuck closed if ok bad control board
Posted on Apr 01, 2020
5 Related Answers
oscarn
Oscar Netto
  • 110 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
Anonymous
  • 54 Answers
SOURCE: 2 problems.. AC Comp cuts out. And Fan will not stop.
Unit#2 -Sounds like the contacts on the master switch are welded closed or the switch is broken, Replacing the switch should fix this unit.
#1 is a little more difficult to diagnose. The compressor is being taken off line by a circuit that protects the compressor from damage either; 1- liquid refrigerant getting back to the compressor which can be caused by something as simple as a clogged return air filter or evaporator coil on a heat pump or 2- overload situation caused by a bad condenser motor or a clogged condenser coil. The first thing you need to do is clean both coils and replace the filter,. Then check to be sure your getting good airflow across both coils. I think it's most likely an airflow issue I hope this resolves the problem GL!
Posted on Jun 12, 2008
Anonymous
  • 6 Answers
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Posted on Sep 09, 2008
Anonymous
  • 3 Answers
SOURCE: amana ptac
you have the white wire on the wrong terminal put it on the same terminal as the red wire on the capacitor and you should be fine,
Posted on Jan 06, 2009
Anonymous
  • 142 Answers
SOURCE: Amana PTAC ptc093d35ar, when i
H1=High voltage protection engaged. Power supply voltage is too high. Check for incoming power at correct voltage.
Posted on Feb 10, 2009
What does it mean when it indicates stop?
Wow, a talking AC?
How to Reset an Amana PTAC - YouTube
? 0:55
www.youtube.com/watch?v=D4SQfFChiKY
Mar 28, 2014 - Uploaded by Total Home Supply If you ever need to reset your Amana PTAC this simple guide will ... HVAC AC Blower not working, troubleshooting Fan Control board, Fan not ...
Aug 21, 2015 | Amana Heating & Cooling
PTAC is not blowing cold air.
bad switch, bad motor capacitor, bad motor.
Jul 27, 2015 | Amana PTH093E35AXXX
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
Jun 19, 2010 | Amana PTH093B35AM Thru-Wall/Window Air...
Amana PTAC cannot be turned on.
sound like a thermister problem, however this may also be a circuit board problem, the system is controled by the outdoor board, check to see if you have a blown inline fuse in the outdoor unit, it will be under a red case in one of the wires.
Jan 28, 2010 | Heating & Cooling
Amana ptac
Dec 27, 2008 | Amana PTH123B25AJ Heat Pump Air...
Ptac unit not heating, but fan,thermostat switch and ac is working. Please advise the solution to the problem. Thank you.
sounds like your control board could be bad,I'm a master a/c tech I work on these from time to time and I have more problems with the control boards,what brand is it
Nov 16, 2008 | Amana Heating & Cooling
Jun 11, 2008 | Amana PTH123B25AJ Heat Pump Air...
Ptac fan keeps blowing
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
101 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
WatsHVAC
Level 1 Expert
Brad Scarpetta
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
