Question about JVC Video Cameras
What cord do I need to purchase to connect a JVC GR-DVL305 camcorder to a VCR or Mac Computer?
Posted by Marri Wiebelhaus on
DMS-UK
    Scholar:
    New Friend:
  • 81 Answers
Hi The GR-DVL305 should have come with a composite AV cable (a 3.5mm jack to 3 RCA plugs). On the VCR you would need a composite input or possibly a scart input. If you have a scart input you would need a convertor from RCA to Scart (available from Amazon etc.). If you want to connect the camcorder to the Mac it would depend on what Mac. Your Mac may have a FireWire input. If so you can but a firewire cable to connect the JVC to the Mac, but and it's a big but (!) Firewire is not a plug and play system like USB. You will also need software on the Mac that can take the analogue signal from the camcorder and convert it to digital. Hope that helps.
Posted on Jan 24, 2019
5 Related Answers
Anonymous
  • 23 Answers
SOURCE: Connect A JVC GR D31 Camcorder to a Computer Via USB 2
Well I'm afraid not the cable don't not come in such of a way either cause they are different type of cable, but what u can do is buy an external fire wire card for yr PC it comes in PCI format for yr desktop PC. because camcorder in these days do not use USB cables due to the cause that fire wire cable is much faster than the USB ones.
Posted on Nov 28, 2007
Anonymous
  • 1226 Answers
SOURCE: my camcorder
Hello!
If the camcorder can be connected to the computer there is big posibility that can be downloaded,
Install all the enclosed softwares into the computer and then connect the camcorder, REfer to the user manual regarding the copying of video to the computer. http://books.jvcservice.com/booklist.asp?Model=GR-SXM37US
and the software please refer here:
http://support.jvc.com/consumer/custrel/index.jsp
may this help!
melnavz
Posted on Feb 07, 2008
kala
JAYA SANKAR
  • 156 Answers
SOURCE: JVC GR-D250 Mini DV Digital Camcorder Authorised service center in pune india
This model is not supporting with pc when you play cassette only it is supporting with memory stick
Posted on Feb 28, 2008
Anonymous
SOURCE: JVC GR-DVL20E
If you have a DVD recorder you can put your film onto a DVD through the tv - that's how I've done it. Hope this helps.
Posted on Jun 07, 2009
Anonymous
  • 3 Answers
SOURCE: Need disk software for jvc gr-d70u camcorder
You don't have to have the software that came with your camera. There are many video capture programs out there. I use Nero Express, but Movie Maker might work too.
I have been unable to import from my camera to my computer for three years, thinking that the problem was the camera. I would plug in the Firewire cord that came with the camera and would get nothing, even on other computers. As a last resort, I got a new Firewire cord today. As soon as I plugged it in and turned the unit to Play, the computer recognized my camera!!!! I am SO excited! When your computer recognizes the camera, it will bring up the programs on your computer that are most likely able to allow you to import the video.
The problem the entire time was the cord! The cord that came with my camera is now in the trash, and I can finally import videos!
Posted on Jul 13, 2009
How can I transfer from my JVC GR-FXM40EK to PC?
JVC GR-FXM40EK is analog camcorder that can not be connected directly with computer because computer needs digital video format to save the file so connect USB 2.0 Video Capture Device in computer and plug camcorder AV wires in that device that will digitize the AV signals of analog camcorder and computer will save it in your selected folder on hard disk.
Hope this will help.
Aug 07, 2011 | JVC GR-FXM40EK Camcorder
How to play/download/transfer video from JVC camcorder to my Mac laptop JVD GR-DVL815
i lost my original install disk JVC GR-D350as Mini DV Digital Camcorder Driverand i need a web site that lets me install it
Mar 31, 2011 | JVC GR-DVL815 Mini DV Digital Camcorder
I need to download software for a jvc GR-D870U
i need to download software for a jvc gr-d870u
Aug 17, 2010 | JVC GR-D870 Mini DV Camcorder
Downloading Video to my Computer from a JVC GR-SXM920
You need a video capture card that supports analog inputs. Connect the video and audio out jacks from the camera to the computer. You will need some sort of software also. The Movie Maker software that comes with Windows XP would work.
The little cord that came with the camera will not transfer the video.
Feb 17, 2009 | JVC GR-SXM920 Camcorder
JVC GR-DVL20E
i HAVE THE SAME CAMERA AND HAVE ALWAYS CONNECTED USING A FIREWIRE LEAD WHICH I PURCHASED SEPERATELY it's under oneof the rubber flaps and is called DVOUT. You will need to purchase a firewire lead which has that small connection on one end and whatever size your firewireport connection is, on the other
Nov 24, 2008 | JVC GR-DVL20EG Mini DV Digital Camcorder
Jvc gr-d72u
use firewire cable from your dv port to stream video-4-4 pin for laptop 4-6 pin for mac or tower
May 17, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Camcorder
Here is the link for the manual if you need it; http://books.jvcservice.com/download/686501845/13178.pdf Page 29 shows the connections for video output to a tv or vcr so either of these configurations would work to a video capture card installed in your pc (please ask again if you need more info on these cards - a quick walk round your local computer shop should give you an idea, and they will also have the necessary cables.) Hope this helps :)
Feb 25, 2007 | JVC GR-AX310 VHS-C Analog Camcorder
Help meeee pls! JVC mini DV cam problems
just joking althoe macs are crap tho,you need a firewire cable and firewire support on your mac its that easy,you just plug in and the pc does the rest,not sure about mac thoe cause there crap
Jan 03, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Digital camcorder to convert VHS tape to PC for DVD burn
You can't with what you've got I hate to be the bearer of bad news, but in order to play tapes in a vcr and run them through a digital camcorder for output to a computer, the camcorder must have s-video or av inputs. Your camera only has s-video or av outputs, used for sending from the camera to the vcr or tv. Also, some cameras have the inputs but don't support analog to digital pass-through (which is what you are describing). With these cameras you input from the vcr and record it to the tape in the camera, and then output it to the computer. Without the inputs, you can't do either one.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Video Cameras Logo
237 people viewed this question
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
