This usually means that the batteries need to be replaced. Make sure you check the type of batteries needed for your timer, and replace them according to the instructions. If the issue persists after replacing the batteries, you may need to contact the manufacturer or a qualified technician for further assistance
SOURCE: Intermatic ST01C is a wall timer for my outside
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
ST01C manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
1) Manual shows troubleshooting steps. Since ST01C is battery operated, it will
not work on loads farther than 100 feet away. If a wire is buried
underground, this can interfere with operation. Other electrical devices can
interfere with operation. Check for interference issues.
2) Try reprogramming timer
To program the ST01C:
http://waterheatertimer.org/ST01C-program.html
3) ST01C has 1 year warranty + troubleshooting steps in manual, implying short life expectancy. Similar EJ500 has troubleshooting + 1 year warranty. Similar Intermatic EI600 battery-powered has troubleshooting + 5 year warranty. Each offers 40 programs per week.
3) Other in-wall programmable timers offer 7 on and 7 off events per week. Clock operates on 120V instead of battery. Ttroubleshooting is: reprogram.
http://waterheatertimer.org/Programmable.html#progr
SOURCE: We installed the EJ500 about 3 years ago. Recently
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
The EJ500 comes with a 1 year limited warranty. It may be time for a new timer.
Buy at:
http://www.aplussupply.com/intermatic/timer.htm
SOURCE: I need the user manual for an Intermatic wall
You can download the maunal here.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej500c.aspx
Good luck
