Seiki 50 SE50UY04
It sounds to me that it is possibly in another mode ie. PC, HDMI, etc. and when reset to default goes to tv, but once turned off, goes back to the other mode. I would suggest going to menu and instead of going to default, go to TV and set it for that mode. You may have to do this very quickly upon startup before it goes to another mode.
SOURCE: After power outage, TV screen is blank
It sounds funny but, unplug the set for 30 seconds to allow the TV to reset then see if the problem still is there.
SOURCE: toshiba dvd setting
1. You would press and hold stop on the front of the unit for 5 seconds then let go and press it again normally, you can try this with both the power of the unit on and off.
SOURCE: mitsubishi WS-55311 flashing screen
First suggestion is to unplug your unit for 24 hours, if does not correct your concerns, you may have fluid leakage from the tubes onto the pc boards. Make sure you have proper air venting around the tv. If problem persist call factory authorized dealer in your area. good luck
SOURCE: blackjack II blank start screen
Hi dogbyte,
For some reason, certain Windows Mobile (Standard) devices don't like "list" format for the Start Menu.
Give this a try:
1) Remove the battery for 1-2 minutes. (This allows any cached memory to clear)
2) Power the device back up.
3) Before openning ANY other apps, navigate to Start > Settings > Display > Start Menu Style
4) Change this value from "List" to "Grid"
5) Click Done twice, then click the Home key.
6) Give the Start menu another try. (Does this resolve the issue?)
Another forum suggested that Windows Mobile seems to be a little picky about which application appears first on the Start Menu. If you have any custom applications installed, it's possible WinMo's start menu just isn't playing nicely.
Hope this helps!
SOURCE: Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
