Question about Navman GPS
My Navman wont charge There is a red light on And it shows a picture of a satnav and a computer on the screen
Posted by [email protected] on
5 Related Answers
Anonymous
SOURCE: navman F10 wont function shows sat nav connecting to computer on screen
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
Posted on Jun 19, 2008
Anonymous
  • 135 Answers
SOURCE: Screen is showing computer, usb
The F20 Desktop Software and Service pack on the CD's from navman do not work, as you have seen. The solution is to go to the navman website and download this Service Pack
Be sure your f20 is connected to the USB cable and turned on displaying the USB Connection screen. Leave it on during the entire process.
Once downloaded, run this self extracting file and let it install automatically. After it is installed and ran.....you will see the same error again of failure to connect.
At this point you must reinstall the driver manually. Right click on your "My Computer icon, Select Devices, then properties on the navman. You should see a yellow "?" next to a statement "Unknown Device" in the USB devices. Click on the "Reinstall Driver" and select a specific location or the Have Disk button. The USB driver is now located in C:\program files\Navman\f20servicepack\USB directory.
You should get a button that now says Okay at the bottom, click onto it and allow the MS program to update the drivers. You should see the device screen change and say "This device is operating properly". You can then close the windows and run the F20 desktop program. It should connect then.
Posted on Jul 06, 2008
Anonymous
SOURCE: my navman f20 wont charge
mine won't charge either!
Posted on Oct 23, 2008
Anonymous
SOURCE: SAT NAV NOT COMMING ON
try putting needle in reset button underneath
Posted on Dec 23, 2008
Anonymous
  • 45 Answers
SOURCE: Navman Satnav icn530
Did you tried to recover keys with SmartST ? The option is on the software menu
Posted on Apr 10, 2009
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
When i turn my satnav on open page comes on and then it showes a picture of satnav charging from a laptop and will not go to anything else can u help me please thanks graham
Hi Graham,I had exactly the same problem with my Nav Man S50. After the icon of the lap top my screen went blank. I updated it via the soft ware provided but no updates were available. In fact the problem turned out to be the on/off switch. Although it was glowing red it was not charging. I simply placed a pen into the switch and it worked.
Hope this will help.
Maureen
Sep 04, 2011 | Navman S50 Portable GPS Automobile...
How do I charge my garmin 1300 gps
You can charge it using the car charger that came with it by plugging it into the cigarette lighter socket of your car and the narrow end into the back of the satnav. You need to have power going to the cigarette lighter socket. On some cars that means that the car has to be running. There's a little led (light) on the plug which shows when it's receiving power. Charging this way takes about 4 hours.
You can also charge the satnav using an optional mains charger which also takes 4 hours.
Finally you can charge it by connecting it to the USB port of a computer for 8 hours. Both the computer and the satnav need to be on.
There's a battery state indicator on the screen of the satnav which shows if the battery is charged or not, on the screen which shows WHERE TO and VIEW MAP. It only shows when the satnav is not connected to a power source so you need to stop charging it to view it.
Jul 13, 2011 | Garmin GPS
Nuvi wont turn on
No the red light comes on to show that there is power going to the Satnav. In most Garmins the Battery Strength meter is in the home screen. Generally people leave the satnav plugged in when driving regardless of whether the battery is charged or not.
Jul 16, 2010 | Garmin nuvi 200W GPS Receiver
My navman s30 has a picture of a computerrunning a link to a USB
http://www.navman.com/in-car/europe/uk/Products/Sat-Nav-Devices/S30/Technical-Specifications/
Software likely corrupted,, Download any updates especially firmware updates at the link above. You will be required to register you device, then you should be able to download and install anything you need.
If you need more help feel free to contact me, I CAN help with this,
Thanks,
Jim
Aug 04, 2009 | Navman F20 GPS Receiver
I have a navman s90i . When i plug the car charger in the screen shows a compuyer runing into a navman via a cable then shuts down then try's to start but goes to the above screen
No solution but exactly the same model and exactly the same problem. When I put the car charger on the unit, it goes off and then comes back on and ust shows a computer as though the only option it can handle via usb is a computer connection. Interestingly, it still charges, but just becomes useless as a satnav as there are no maps, directions or any scree functionality at all.
Nov 22, 2008 | Navman GPS
Reset navman F10 sat nav
Press and hold the on/off button for ten seconds will re-set the system on the satnav. If the screen freezes after loading the maps then connect the Satnav to a pc via a usb lead and download the latest Service update fom Navman.com. With the Satnav connected to the computer and the download compleated double-click the F10 set-up.Exe and it will update the system on the Satnav. Once complete disconnect the cable and restart the F10. That was the way I sorted mine out after recieving 'little' help from Tech Support from Navman.com. My problem seems to be in the Multi-drop ability of the F10 [program one location and try and add another to plan a route] but I have never got anyhelp from the tech's other than "Buy a Connectivity kit from us and you may be able to use that to fix the problem....". If you get a "Not enough memory to complete update... " message after double clicking the F10 set-up, you will need to go into your F10 Satnav memory and look up some of the saved files from previous routes you have stored in there. I deleated some of these to free memory and it didn't seem to affect the Satnav's programming and allowed the update to complete. My F10 started fine after that. If you need any more help, Navman.com tech support may be able to suggest something....., just don't hold your breath....
Sep 23, 2008 | GPS
Navman F10 wont function shows sat nav connecting to computer on screen
Jun 10, 2008 | Navman F20 GPS Receiver
GPS Logo
254 people viewed this question
Top Navman GPS Experts
Ekse
Marvin
Marvin
Are you a Navman GPS Expert? Answer questions, earn points and help others
