Question about SanDisk Sansa e250 MP3 Player
I cant get my sansa to work on my computer
Ok so when i plug in my Sansa clip to my computer (laptop) it makes the ding like its working but when i go to my computer its not there and i leave it on all night and it doesnt even charge the battery however it does work on other computers. It worked on my friends old piece of crap computer and the one at my work but not any of mine at home. I dont understand. Please help
Posted by cloverpla4 on
  • cloverpla4 Nov 26, 2007
    Yeah I've been researching it and that's what i figure too but i dont know how to check that. I have an emachine laptop and its a few years old so i bet it doesnt have 2.0 USB port so that's probably it. I've restarted my computer several times to try it again and nothin so i bet it's my USB port. Thanks though
    Yeah I've done some research and that's what i figure too. I've tried the restart tactic and it didnt work. I have an emachine laptop so i figure the low grade USB port is my problem but thanks :)
Anonymous
Maybe it has to do with the USB port being 2.0 or not, i had a similar problem but i restarted the computer and it worked,
Posted on Nov 26, 2007
I left my Sansa Clip MP3 Player plugged in while putting my laptop into hibernation. Now player does not response, I can't turn it on, and laptop doesn't recognize it at all.
    Complete Reset of Sansa Clip
  1. Step 1 Turn Sansa Clip on. Press the "Menu" (Home) button on the Sansa Clip.
  2. Step 2 Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
  3. Step 3 Scroll down to "Reset All," and select. You will be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow steps 4 and 5.
  4. Step 4 In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm if you wish to format. Select "Yes."
  5. Step 5 Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
  6. Resetting a Frozen Sansa Clip
  7. Step 1 Unfreeze a frozen Sansa Clip by pushing the power button up and holding it for 20 seconds. Release it, and then turn it on again.
  8. Step 2 Go to the Sansa website and download the "Sansa Firmware Updater."
  9. Step 3 Select "Run" when the updater installs. (Installation will take less than two minutes.)
  10. Step 4 Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
  11. Step 5 Connect the Sansa Clip and then remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Aug 22, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip does not show up on computer
I had the same problem all you've got to do is first turn on the sansa clip.Then go to settings. After that scroll down to USB mode (second from bottom) then it woul probably say auto detect. Scroll down to MSC then hit enter. If that doesn't work try MTP mode.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
SANSA
My computer not recognise sansaclip
Jun 24, 2008 | SanDisk Sansa Clip MP3 Player
Computer not recognizing mp3 sansa clip
Comment by vickisanchez, posted on Mar 19, 2008 IT FINALLY WORKS !!!!
Sandisk Tech support had me do the following:
- Turn it OFF
- Put it in the HOLD position
- HOLD the center button IN while plugging into USB port, continue to hold for 5 to 7 sec even after plugged in.
At this point MY COMPUTER recognized it. And it worked.
He also had me to:
- go to WWW.MICROSOFT.COM
- In the upper right hand search bar, type in MTP PORTING KIT
I did this and downloaded the first one. Now my Sansa Clip work perfect. I wish I would have talked to him last week before I returned the last one, for the same reasons.
If this does not help call the 1-800 # , opt #4, and ask for GUY (yes that is really his name) out of 5 or so calls to Tech Support he is the only one who knew what he was doing, and how to actually HELP.
GOOD LUCK
Apr 09, 2008 | SanDisk Sansa Clip MP3 Player
Does not recognize
- Turn it OFF
He also had me to:
GOOD LUCK
Mar 09, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip problems with driver
- Turn it OFF
He also had me to:
GOOD LUCK
Mar 01, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e250 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
