Question about Brookstone Office Equipment & Supplies
Is there anywhere I can get a calibration sheet from for my brookstone iPhoto scanner??? ????
Posted by Lisa Noteboom on
1 Related Answer
Anonymous
SOURCE: where can I find a calibration sheet for an Ambir scanner Ps667?
They gave me a direct link to download the config sheet. http://www.ambir.com/FTP/PDFs/665CP.pdf
Posted on Sep 14, 2012
1helpful
How can I get the calibration sheet for ambir scanner 820i to print?
You can purchase a package of calibration sheets from the Ambir site: https://www.ambir.com/product-category/scanner-accessories/page/2/ . You can use a plain white sheet of 8 1/2" x 11" paper as a temporary calibration sheet. The image quality won't be as good but it will work.
I hope this helps.
What is calibration sheet,and where do i find one?
Hi, the calibration sheet being referred to was sent with the printer, it's a piece of cardboard ( white with one corner missing). Please check the packaging if you still have it, otherwise borrow one from a friend. All the best.
Calibration sheet
Ambir sell calibration sheets on their website.
Ambir Scanner Accessories
6helpful
Brookstone iconvert not saving getting errors
On iPad goto Settings -> Privacy-> Photos
Turn on iConvert Scanner
12helpful
3answers
Where can I find a calibration sheet for an Ambir scanner Ps667?
4helpful
CRS Photo Scanner Drivers
I have just had the same problem. Have you found any solution anywhere else?
My kodak easyshare5300 is printing black picture
Hi-
If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
Try this first
Calibrate your printer, then print a demo sheet.
  1. If paper is in the photo paper tray, remove it.
  2. Load photo paper into the photo tray.
    1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
    2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
  3. Calibrate your printer.
    1. Press Menu.
    2. Select Calibrate Printer, then press Start.
    3. Wait for your printer to print the calibration sheet.
    4. Place the calibration sheet face down on the scanner glass.
      • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
      • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
    5. Press Start.
    6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
    7. Remove the calibration sheet from the scanner glass, then press OK.
  4. Print a demo sheet.
    1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
    2. Select Print Demo Page, then press Start.
    3. Wait for the demo sheet to print.
Then call them if issue Persist at these numbers:
In the U.S. and Canada: 1-800-421-6699
In Australia and New Zealand: 1800 793 895
Thanks for using Fixya!
1helpful
2answers
NO CALIBRATION SHEET
Hello, you can print a calibration sheet from the front panel of the printer. Hit menu on the panel of the printer and scroll down to calibration printer and hit ok. Then hit ok on print calibration page and it should proceed to print a calibration page. After it is done printing, it will tell you to scan the calibration sheet.
Top Brookstone Office Equipment & Supplies Experts
Ekse
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
