Question about Jensen Car Audio & Video
Im having trouble with a new jensen vx6628 radio. I purchased new installed it played for a few days then it came on with no sound but not muted.Then yesterday it came back on and now today no sound.
Posted by Mike Tipton on
Jeff McCrea
    Novelist:
  • 144 Answers
Does it have a removable control head? If so, be sure that it is correctly seated and snapped into place. Also be sure that all plugs are securely seated like power, clock, speaker and antenna plugs. Good luck
Posted on Jan 03, 2019
5 Related Answers
Anonymous
  • 72 Answers
SOURCE: jensen vm9411 no sound
Check to make sure your vehicle does not have a factory amplifier. If you used a fit kit with wiring harness. try looking at how many wires were used in the factory unit compared to haw many you are using now. see if there are extra wires in the vehicle. If there is extra wires it is a pretty good clue the vehicle has an amplifier and will have to be rewired.
Posted on Sep 01, 2006
Anonymous
  • 74 Answers
SOURCE: sub not working after installing the jensen vm9022 deck
reinstall the factory radio use a digital volt meter to see witch wire supplies voltage when radio is turned on and off, note placement on harness then verify this wire is hooked up on the output side aftermarket harness you may have to jump it to get the maps to turn on. tip you can carefully pull unused wire from harness example (dimmer wire orange white) and move it to the position needed to keep it a clean install .
Posted on Nov 21, 2008
Anonymous
SOURCE: CD player that doesn't play
I had the same problem.
I cut the orange wire which went into the black connecter block
and WOW I had sound...
brilliant
thanks a lot
Andy - North Yorkshire, England
Posted on Feb 24, 2009
Anonymous
  • 11 Answers
SOURCE: Mute function on Pioneer AVIC-N1
You have to isolate yellow-black cabel. This cabel was in contact with earth and it was the reason, why you have Mute on the display.
Posted on Sep 14, 2009
m111den
m111den
  • 94 Answers
SOURCE: parrot universal radio mute is broken
daltac.co.uk
Posted on Mar 03, 2010
How can I get sound from my radio
If a cable speaker is shorted to ground or (in your case) the short was on the casing the radio mutes the output to save the amp. So
remove all cables and put them back to the radio & connect the speakers one by one to see if it works or mutes again
Sep 30, 2016 | Jensen Jta-475 Cd Player /turntable...
Polk audio sound bar 4000 comes on no sound
try to re-installing the driver .
if not solved , may be the speaker damaged .
May 25, 2014 | Polk Audio SurroundBar 4000 IHT Virtual...
No Sound from Jensen VM9725BT
Jimmie Monica Hey, Its not a problem with the unit. You have the blue or Blue/White wire hooked up wrong. Disconnect both the blue wire and the blue and white wire and I guarantee the sound starts working on everything. If you have one of those two wires hooked up for a power antenna or remote amp turn on, then switch which one you are using and that will fix the problem permanently. Disconnecting them both will get it to work though. I guarantee it. Please post back and let me know if it works for you. Thanks
Sep 06, 2013
Feb 22, 2013 | Jensen VM9725BT Navigation receiver
No sound
hi! press the audio setting and set on the audio set on
Sep 08, 2009 | Jensen VM9020TS Car DVD Player
My Crosley combination turntable/CD/cassette/AM & FM radio has recently started giving me fits. I bought it new in 2003 and, until a few months ago, it worked great. But now the turntable arm won't click...
my Crosley CR6007A-MA turntable's sound is very, very low. You can't even hear it barely. I haven't had it long at all and it wasn't broke due to any sort of abuse. I really have no idea why it would do this for no reason! Help!
Apr 01, 2009 | Crosley Audio Players & Recorders
Mute keeps activating by itself
easy guys ill explain, if you pull the deck out and expose the wiring in the back you will see a small pink wire with a plastic and metal end, that wire is your parking break bypass wire,wut i did with my car was created a switch, its very easy, all you need to do is go to radio and purchase a ON/Off switch, it will have only two metal connector ends on that switch, basically all ya gotta do is find a suitable grounding spot for the negative or OFF side of the switch and then for the positive side...you guessed it attach the pink wire to the positive side. I had to make the pink wire longer for my switch location so if you know how to solder I wuld reccomend doing that than any other ghetto method, such as electric taping it and calling it a day, ding that may damage the system in the future
Jan 02, 2009 | Jensen VM9510 Car DVD Player
Jensen vm9511ts cuts out
It sounds like the phone mute is going on and off, but I'm just guessing because I don't know your grounds, speaker wire hookup configuration, etc. Look at the screen when the music cuts off and goes back on and if you see a little red phone with the cross through speaker symbol (aka mute) it's probably the phone mute feature which is supposed to be hooked up to bluetooth and mute the stereo when you get a call. Like I said I'm just guessing, but if so there's a brown wire in the back that needs to be hooked up.
Jun 19, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Car Audio & Video Logo
71 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Muntejaya Ginting
Muntejaya Ginting
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
