Question about Weiser Lock Locks & Locksmithing
How to remove battery cover on older weiser lock
Chris Walker
    Top Expert:
  • 1,551 Answers
Posted on Mar 20, 2019
1 Related Answer
Anonymous
  • 15 Answers
SOURCE: Weiser combination lock beeps
You should check if the keyboard ribbon cable is properly connected and not pinched or cut ... Also it is possible that water has entered into the keyboard. In case you should remove and dry with a hair dryer.
Posted on May 15, 2011
How do I replace batteries in weiser keysless lock?
Not sure on a Weiser but on mine there are small Allen screws on each side of the cover that have to be removed that allow the cover to be removed.
Change batteries in weiser Powerbolt elec deadbolt
Pull the inside cover away from the door, to remove. This exposes the battery holder. Replace all four AA batteries with new alkaline AAs The cover snaps on. Align top first.
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
I guess I need to purchase a new cap that goes over the pins. Mine is missing and my door unlocks when the lock button is pushed,
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
2helpful
Weiser Power deadbolt works backwards on keypad
Cannot remove the plastic cover to access the battery and to change the code - an older model I believe.
Weiserlock Powerbolt 1000
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
If you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
How to remove covere to replace batteries?
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
I cannot get the cover off to change batteries
Removing the cover is described and illustrated here:
"Press down on the inner battery cover (as indicated by red arrow in image below) to relieve tension on the bottom portion of the cover. While pushing down on the top of the battery cover, pull the bottom of the cover towards you to remove."
My lock, weiser lock Powerbolt, right now is locking from left to right. I installed the double-door. The lock requires locking mechanism from right to left. How do you program it.
I think this link answers your question:
5helpful
Battery cover wont come off
Locks & Locksmithing Logo
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
