Question about Mercury Boating
Mercury outboard,, 7.5 hp Serial no 8065967 Year of manufacture please
Posted by Othmar Goyer on
cluffermon
  • 4 Answers
If the serial number is 3065967, it is a 1971.
(Not 80659677??)
It appears that the last year produced was 1976 with serial numbers starting with 4314385.
8 and 3 misreading is not uncommon.
Posted on Jan 06, 2019
5 Related Answers
Anonymous
SOURCE: 9.8 hp mercury outboard shutting off in low idle speed.
My problem ended up being the spring on the reed valve being weak.But at the same time and while I had already had my carb broke down I took a can of carb cleaner to it and cleaned it. In order to replace the spring on reed valve you will have to buy a new one, but don't worry I only payed about $6.00 for mine. You may also look into replacing your primer bulb if you haven't already because may allowing air to build up in your gas line while you are basically idiling.Once you get the carb straightened out you may have to reajust it again. If I might be able to help you again you may contact me at [email protected].
Posted on Jun 16, 2009
Mark Chapman
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
Posted on Sep 20, 2009
ray gallant
  • 69148 Answers
SOURCE: where is the serial number on mercury 115hp 6 cylinder boat motor
http://www.marineengine.com/mfr/mercury_models.html
Posted on May 01, 2010
Anonymous
SOURCE: 2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
Posted on Jun 29, 2010
JEM
  • 406 Answers
SOURCE: what is the year model of a evinrude outboard motor with the serial number 1503201749
try reading this on ehow http://www.ehow.com/facts_7292301_evinrude-year-identification.html
Posted on Jul 27, 2014
I have a mercury 75hp outboard ser#OD020354 would like to know what year the motor is
QUESTION:
How can I determine when my outboard was built?
ANSWER:
Every Mercury outboard has a serial number label located on the transom bracket area of the engine. The latest serial number labels display a 2-digit number in a box at the lower right portion of the label. These digits coincide with the last two digits of the year in which the outboard was manufactured. For example, if an outboard was manufactured in 2010, the number "10" would appear in the box at the lower right portion of the label.
May 01, 2017 | Mercury Boating
75 horse power ercurywhat year of manufacture serial number 06255293
There is no data included in the serial number that gives info of what year the engine was made. You can, however look up the number here, and that will tell you the year of manufactor.
http://www.iboats.com/basics/serial_number_year.html#mercury
Aug 15, 2014 | Clymer Mercury/mariner 75-275 Hp...
What year is my mercury outboard
What year is my Kiekhefer Mercury Outboard SN 389664, Mdl-KF-7
Jan 05, 2014 | Clymer EvinrudeJohnson Outboard Shop...
What is the year of a mercury marine serial #08308043
Aug 18, 2013 | Computers & Internet
Need to know year model for mercury 6hp serial 9494287
I was able to find the following information regarding 6 HP manufactured by Mercury. You can find more information on the boating forums.
http://forums.iboats.com/mercury-mariner-outboards-25/
HP
Cyl.
Beginning Serial #
Year
6214086111961621485612196262155144319636216075131964621745521196562195827819666220961711967622284857196862A910596198662B114231198762B233200198862B3855001989
Mar 14, 2013 | Boating
Serial Number 1001499 Model Mark 25 Mercury Outboard what year?
pinched rom another website:
Jan 06, 2013 | Boating
What year is my mercury 40 hp (402)please the number is 9034091
According to marineengine.com, it looks like it could be in the 1983 sequence of serial numbers.
Aug 29, 2011 | Seloc Mercury Outboard Engine Repair...
Boating Logo
251 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
ray gallant
Are you a Mercury Boating Expert? Answer questions, earn points and help others
