Question about Frigidaire Heating & Cooling
SOURCE: Ductless heat pump systems
Fixr is correct. I do not recommend using the Mitsubishi or Sanyo below 17 degrees. It may cost you a fortune in electricity below 50 degrees depending upon where you live. Mitsubishi is the better model.
Posted on Nov 19, 2007
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
SOURCE: Have RHOSS heat pump showing E01
Different manufacturers use different codes, as I am sure you have figured out. Most of them that I have run into E-01 means the inside and outside units are not communicating. One is without power or there is a broken or loose wire.
Posted on Jul 19, 2010
SOURCE: Ductless mini split heat pump comfort-aire error codes
E:1 room temp. sensor fault. / indoor unit.
see more pls Air Conditioning Fault Codes
Posted on Jul 06, 2014
May 21, 2017 | Honeywell Heating & Cooling
Sep 06, 2015 | Pioneer Ductless Mini Split INVERTER Air...
Nov 14, 2014 | Pioneer Ductless Mini Split INVERTER Air...
Oct 04, 2014 | Mitsubishi MXZ-2B20NA-1 Mr. Slim Dual Zone...
Jul 06, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Mar 02, 2014 | Jeep Compass Cars & Trucks
Sep 21, 2017 | Heating & Cooling
Oct 12, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
May 02, 2010 | LG LA185HV Split System Air Conditioner
Jan 23, 2009 | Continental CE-AC75271 Ductless Mini Split...
100 people viewed this question
The question marks were supposed to be a snowflake.
