Question about LaCie Computers & Internet
I have a Lacie external drive when the power plug connection on the circuit board broke off. Can the circuit board be repaired or replaced?
Posted by T Aparicio on
Dayton Computer
  • LaCie Master
  • 1,578 Answers
Replace perhaps, but repair is most difficult. The electronics are miniature and it takes special tools to do repairs.
Posted on Jan 02, 2019
5 Related Answers
Anonymous
SOURCE: lacie d2 external drive
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
Posted on Jan 08, 2008
Anonymous
SOURCE: external hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Posted on Sep 08, 2008
Anonymous
  • 6 Answers
SOURCE: GATEWAY ta6 WAS DROPPED ON
Try here - detailed photos for same problem on different model Gateway:
http://www.insidemylaptop.com/take-apart-gateway-nx570x-laptop-disassembly-guide/
Posted on Apr 25, 2009
Anonymous
  • 284 Answers
SOURCE: I have a LaCie external harddrive that refused to
i too have had this problem and it generaly means it is broken. sometimes things can be done but it is very costly
Posted on Jan 23, 2010
Anonymous
  • 3 Answers
SOURCE: lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Posted on Sep 13, 2010
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
My lacie external hard drive doesn't show up on my desktop when plugged in
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Aug 08, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie Big Disk External Hard Drive suddenly not recognized by USB or Firewire. Have traveled on the road with this drive across the country. On return from last trip the drive is not being recognized.
Hello
Kind Regards
Andrea
Jun 28, 2010 | LaCie Big Disk External USB 2.0 1TB Hard...
Lacie external hard drive isn't being recognized by my Mac G5
Hello
Kind Regards
Andrea
Oct 13, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
PLEASE help me! My Lacie External Hard Drive is NOT powering on...all my important data is on there - need help!!!!
Hello
Kind Regards
Andrea
Oct 02, 2009 | LaCie Ethernet Disk mini USB 2.0 External...
LaCie 1TB external hard drive is not registering with my desktop MAC OSX 10.5.7
Hello
Kind Regards
Andrea
Jul 07, 2009 | LaCie Big Disk Extreme with Triple...
External Hard drive failed
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Kind Regards
Andrea
May 13, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My LaCie external hard drive isn't showing up on my desktop when I plug it in. This is only a recent problem, and I'm worried, because I can't access all of my backed up files.
Hello
Kind Regards
Andrea
Mar 11, 2009 | LaCie USB 2.0 Mobile 40GB 5400rpm 480Mbps...
Lacie hard drive
The problem is just external...Hdd is fine..Just buy new external couse there is no way to repair it
Jan 12, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie d2 external drive
Sep 24, 2007 | LaCie d2 (300769) 200 GB Hard Drive
Computers & Internet Logo
100 people viewed this question
Top LaCie Computers & Internet Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
